Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Low cost LCD oscilloscope and DIY kit
Old 20th December 2008, 04:36 AM   #11
jazzy939 is offline jazzy939  Malaysia
jazzy939's Avatar
Good for you mindcrime!
Please update us when you're done building it. I am planning to buy it too....
But how come seedstudio's price is cheaper than jyetech?
Old 21st December 2008, 02:06 AM   #12
Mindcrime is offline Mindcrime  United States
It seems the one I bought does not come with the power supply, that must be how they keep the shipping cost down. I have plenty of those floating around, so thats ok with me
Old 8th January 2009, 06:05 PM   #13
rob lenk is offline rob lenk  United States
Default o-scope
ray
looks like a good little on the road piece- build it into an old plastic case and with a multimeter life is good to go.
two questions- is the$12 screen a direct replacement- ie just plug it into a molex and you are up and going?
can you give me the price of the complete o-scope and extra screen shipped to 04103 and what the wait would be.
Boys want their toys now!
thanks for bringing this to our attention
rob lenk
Old 8th January 2009, 06:39 PM   #14
glt is offline glt  United States
I bought mine from NKCelectronics in the US. You save on shipping. I bought the finished scope. Seems a lot of work to solder those SMD components. Already used it to troubleshoot the I2S output of a CDROM
Old 8th January 2009, 11:31 PM   #15
ray0812 is offline ray0812  China
Rob, the LCD module is the same as the one used in the o-scope. It may take 3 - 4 days to arrive USA if sent from our city. Courier is DHL. Shipping cost is US$23 for 0.5kg. You may like to buy from NKC to save money and time.
Old 9th January 2009, 12:51 PM   #16
n_maher is offline n_maher  United States
Question withdrawn, I see there's a US source that would seem to be the easiest option.
Old 18th February 2009, 12:56 AM   #17
Atilla is offline Atilla  Norway
I just got my hands on one of those and I have to say, it is quite fun to play with. It isn't blasingly fast, the frames per second aren't spectacular, but it does everything it says and does it fairly ok.
Learn how to use it, using the test signal that is built in and going trough the manual, it's fairly simple to grasp.
The frequency counting mode also works great, it counts the 500hz test signal correctly and even manages to properly count the 50hz hum induced trough the power I'm giving it(lousy 9V wall-wart). And that's a very, very low-level hum, a lot under 0.1v, which is the minimum V/div in the meter. I'll try it on a 9V battery at some point to see what it detects there.
For fun, grab the probes and look at your own waveform.
Cool device, now to find something useful to use it for!
Old 29th July 2009, 01:27 PM   #18
This oscilloscope has been upgraded with new firmware. Performance was enhanced and new features were added. These include:
* Higher real-time sampling rate - 5Msps (5Msps works in AUTO mode only)
* Significant faster display refresh rate
* External trig is now available
* Save up to 6 captures to EEPROM and retain after power down
* Retrieve and display saved captures
* Transfer its screen to PC as bitmap file via serial connection
Documents for usage of external trig and troubleshooting were also provided. Please go to http://www.jyetech.com/en/default.html for details.
Old 5th January 2011, 06:07 PM   #19
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
searched to see if anyone here got their hands on one of these toys. I've had mine for more than one year now and have to say that for the price it's great. for most day to day usage of a non-professional its invaluable. and yes, it does everything the package says. recommended
Old 5th January 2011, 06:10 PM   #20
AdamThorne is offline AdamThorne  United States
AdamThorne's Avatar
Do you have the updated one mentioned by ray0812? The video I had seen of this unit made the screen refresh look painfully slow, and I had stayed away for that reason. Is it easy to see the waveform slide around on the screen in real time?
Low cost LCD oscilloscope and DIY kitHide this!Advertise here!
Low-Cost USB Hobby Oscilloscope salesmonster Parts 7 20th November 2008 08:51 AM
Need for Low Cost RF MOS xitronics Parts 0 20th December 2006 01:45 PM
op amp cost pikkujöpö Digital Source 18 10th October 2005 12:07 AM
low cost dac jaudio Digital Source 2 29th September 2005 02:55 PM
the cost of PCB. cccp Chip Amps 5 15th February 2005 09:16 AM
