Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 28th May 2006, 01:31 PM   #41
Russ White is offline Russ White  United States
Russ White's Avatar
Originally posted by awpagan
Russ
any updates on your project?
allan
Getting prototype PCBs made next week after the holiday. Just had to finish off some other projects first. This one is up next.
There will definitely be a USB to I2S converter too. Will probably get that made at the same time. I may contact a few of you to see if you are interested in beta testing the DAC and/or USB PCBs.
The DAC board on its own should be able to go directly into a 10-100K load with no problem (most preamps) , but it would not be filtered at all. I have a third line stage module based on the THS4131 which I will use to filter the output a bit. Balanced input and output.
I will post circuit details here soon. Along with pics of the layout for those who are interested.
One question to anyone who knows, can anyone shoot me a link to a good small input trafo to use for SPDIF that is easy to obtain in the U.S.? I am thinking of including one, but I need to find a good simple example of an SPDIF input circuit using a trafo and identify the trafo I could use.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 28th May 2006, 01:44 PM   #42
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Mr White's "Opus", designing a simple balanced DAC
What, this kind of thing?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 28th May 2006, 01:47 PM   #43
Russ White's Avatar
Now thats a solution I could live with.
Reading it over. Thanks!
Audio
Old 28th May 2006, 02:02 PM   #44
awpagan is offline awpagan  Australia
Cheers!
Russ
I have ordered the eval pcb with some dac's to try.
the reason i like the voltage out is so i can try something like this
http://www.diyaudio.com/forums/showt...pagenumber=193
post 1924
allan
ps also would like to try the software version
Indecision makes the world gone round.
Maybe
Old 28th May 2006, 02:30 PM   #45
Russ White's Avatar
I looked at the site Craig pointed to:
http://www.scientificonversion.com
And found the SC979-03 which seems to be a good fit. I will call them Tuesday to see what the price is and if I can even get them. But they seem small enough.
Thanks Craig.
Cheers!
Russ
Audio
Old 28th May 2006, 02:33 PM   #46
pinkmouse's Avatar
Sowter seem to do one as well, the 8285. They use a strange frames system on their site, so you can't link to the specs directly, but if you go to sowter.co.uk it's under pro audio.
Old 28th May 2006, 04:07 PM   #47
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
Digi-Key also carries some transformers from Newava. Have a couple but have not tested them. 470-1006-ND, 407-1007-ND.
Have to admit that Canare piece looks intriguing if we find a good supplier.
Old 28th May 2006, 05:16 PM   #48
chris719 is offline chris719  United States
That canare transformer is not the right transformer, not even close. It is an impedance matching transformer.
Old 28th May 2006, 05:19 PM   #49
pinkmouse's Avatar
What are we looking for then?
Old 28th May 2006, 05:20 PM   #50
A 1:1 75 ohm pulse transformer, the Newava parts digikey carries will do fine, also the SC parts. If you use the search you can find quite a few threads on them.
Mr White's "Opus", designing a simple balanced DACHide this!Advertise here!
Copyright ©1999-2017 diyAudio
