Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 19th May 2006, 07:16 PM   #31
KOHTOPA is offline KOHTOPA  Europe
Does it make sense to make Lego style DAC with
interchangable modules? For example
- input module/board - separate board for SPDIF to I2S convertion,
separate module for USB to I2S conversion etc.
- DAC itself, with various boards based on different chips WM8740,
PCM1794, CS4398, TDA15xx etc.
- filter, different flavors
- output stage, different solutions - SE, differential etc.
- power supplies, different solutions/boards for analog/digital
sections.
This way it would be easy to experiment by changing different
components. You shouldn't buy/design SPDIF->I2S conversion part
again and again, the same for filter and output stage.
I know that it's a challenge to make such design but I believe
it should be doable, smth. similar to the latest DDDAC Mk2 but
with absolutely all components in this equation in a modular
form.
Old 19th May 2006, 07:18 PM   #32
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
form.
Yes,
Thats the whole idea. But in my case I will simply be starting with the Wolfson DAC. Later I may try others.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 19th May 2006, 07:28 PM   #33
Russ,
Do you make all those functional blocks easily detachable?
What is a form factor for those separate modules? Did you
place power supply(s) on the same board?
Old 19th May 2006, 07:34 PM   #34
Russ White's Avatar
None of them are finalized yet.
But all of the parts I have designed so far are 4" x 1.5" form factor designed to stack. Power supplies would be seperate or optional if on-board.
Cheers!
Russ
Audio
Old 19th May 2006, 07:37 PM   #35
I'm just wondering should I do it myself or wait
till you finish it
Old 19th May 2006, 07:41 PM   #36
Russ White's Avatar
Well the basic DAC board is 90% done, but optimizing the layout a bit.
I also have a balanced filter/linedriver PCB to go with it which I will be testing this evening.
A USB/I2S converter is next in line.
Later I will do an improved S/PDIF receiver PCB whcih can be used in place of the basic S/PDIF input of the basic DAC PCB.
Audio
Old 19th May 2006, 07:52 PM   #37
> bit.
Great progress. I'll wait
Though I'm more interested in USB->I2S because I was able to make
it properly work in my Linux machine. I had some problems with
SPDIF.
Old 28th May 2006, 08:22 AM   #38
awpagan is offline awpagan  Australia
who can supply the wolfson dac? besides wolfson!
I am interested in doing some experiments with this dac also.
i2s>dac> passive filter> simple (discrete)buffer.
Russ
any updates on your project?
allan
Indecision makes the world gone round.
Maybe
Old 28th May 2006, 08:46 AM   #39
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Mr White's "Opus", designing a simple balanced DAC
Allan, you didn't read this thread did you?
Post 22
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 28th May 2006, 09:39 AM   #40
Post 22
Yes i had been.
Tried that site weeks ago and it looked as if it was still being built.
couldn't find refer to wm7840.
just tried again and no problems now.
allan
Maybe
Mr White's "Opus", designing a simple balanced DACHide this!Advertise here!
Copyright ©1999-2017 diyAudio
