Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 25th October 2012, 08:25 PM   #1921
c12mech is offline c12mech  United States
c12mech's Avatar
Thanks Brian. i completely missed that on the website. What about 3 sources? Can two OTTO-II's be used with a switch between them? I'm still not sure what the build will be exactly but am getting the options lined up before I start.
Old 25th October 2012, 08:42 PM   #1922
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Mr White's "Opus", designing a simple balanced DAC
We are contemplating a 4x4:1 version of the OTTO.
Old 25th October 2012, 09:47 PM   #1923
c12mech's Avatar
I got a little more clarification about what is wanted. I2s and AES as the two inputs. Can the OTTO-II do that? I looked and did not see anything that says it can't but would like to know for sure.
Old 5th January 2013, 06:20 PM   #1924
crobbins5421 is offline crobbins5421  United States
Default OPUS Discontinued?
Will more OPUS DAC boards be available?
Old 5th January 2013, 06:23 PM   #1925
Boards should be here Monday. The LCDPS, Toslink, S/PDIF Transceiver and Metronome will be back in stock as well.
Old 5th January 2013, 06:25 PM   #1926
Good news. Thanks.
Old 8th January 2013, 08:18 PM   #1927
Opus is back in stock, along with Metronome, the S/PDIF Transceiver, Toslink module and LCDPS.
Old 9th January 2013, 01:31 AM   #1928
Default Which one?
LCDPS or Placid HD to power the Opus? .....Both look good.
Old 9th January 2013, 01:33 AM   #1929
Russ White is offline Russ White  United States
Russ White's Avatar
Either one.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 8th February 2013, 07:05 PM   #1930
RH75 is offline RH75  Netherlands
Would anybody know if it's possible to bypass the SRC in software mode?
(Hifiduinocode lists them,but not the "unused" one)
Kind of like PS Audio's NativeX,which totally bypasses the SRC and sounds better in this mode.
Mr White's "Opus", designing a simple balanced DACHide this!Advertise here!
