| Twisted Pear Superior quality electronic kits |
#801 |
Sounds like a shorted diode, cap or regulator. DMM time. You should see a high resistance leg to leg on the regulators.
#802 |
Good call, Bob. I have two shorted diodes on the smoking resistor side.
#803 |
Hmm, shorted or backwards diodes. Sounds like something that I would do!
That's why I always 'stuff & test' power supply components first when building a project. The practice saves 'letting the smoke out of' expensive parts and it's a lot easier to probe around a PCB with a DMM without all those parts in the way. Carl |
#804 |
Can you say the type and package of voltage regulator you use on the DAC? Looking to run the digital supply off 3.3V
Many thanks for your assistance. Dan |
#805 | |
LP2985 SOT23, but I am wondering why you would want to do that... Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#806 |
Thanks. I'm wanting to try Wolson's new DAC. It needs a 3.3V digital supply.
Dan |
#807 | |
Rgr that.
#808 | |||
Of course, this brings up the idea of a synchronous reclocker after the isolation, which pushes the entire thing a bit out of my comfort zone. I'll focus on getting sound out of things first, and then look at ways to improve. The ultimate vision of where I think I'm going is pretty complicated, so taking baby steps is probably a good idea to avoid getting lost. |
#809 |
Does the new Wolfson WM8741 work as a drop-in replacement for the WM8740?
Are there any plans of Opus V1.1 with the WM8741? |
#810 | |
Yes it does. The only major reason to do a new board would be to more easily support the DSD input option of the WM8741. We may do it at some point. You can actually fully utilize the WM8741 on the current boards. But some of the pin names have changed, but nothing to difficult to figure out. Cheers! Russ
| Page generated in 0.12305 seconds (74.21% PHP - 25.79% MySQL) with 11 queries |
