| Twisted Pear Superior quality electronic kits |
#51 | |
Found this on Epanorama:
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#52 |
Here is what I am leaning toward right now:
http://rocky.digikey.com/WebLib/Newa...ata/S22160.pdf Should work fine. Any thoughts?
Less pulp more juice Twisted Pear Audio. |
#53 |
Scratch that.... it looks like the S22083 is a better part, it has lower leakage inductance which seems to be the critical spec.
http://rocky.digikey.com/WebLib/Newa...ata/S22083.pdf Now to finish the PCB.
#54 |
Any progress to report Russ?
#55 |
You've got me interested to see your progress as well, Russ. I'd be keen on trying out one of the Wolfson chips on a real DAC (the only experience I've had with them so far is on computer sound cards).
Keep up the good work! |
#56 |
My hope is to order a few prototype PCBs next week.
Would anyone be upset if I omitted the TORX input? Thanks for the ijnterest. Cheers! Russ
#57 |
Hey Russ.
I like the idea of this DAC. I really would like to see what the result is. Keep us informed. |
#58 | |
An optical connection would be great, since my PCMCIA sound card has only an optical output, others many be in the same situation. Also the optical connection eliminates any chances of computer PSU noise getting into the DAC. -David |
#59 |
How about making the input side a seperate module, so you can choose which type you want?
#60 |
Here is the current circuit.
Some notes: 1) I am not sure if I need R9 or not, and if I do if I have the correct value. 2) I have set the WM8740 to reset with the CS8416, which aoocurs on power up after the digital voltage reach 3.3V. 3) Both the digital side of the WM8740 and the CS8516 are running on a singal 3.3V digital supply. The analog side of the WM8740 should be 5V. 4) I will add a legend for al the jumpers and what they do. Cheers! Russ
| Page generated in 0.11655 seconds (74.85% PHP - 25.15% MySQL) with 11 queries |
