Mr White's "Opus", designing a simple balanced DAC - Page 194 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 9th February 2013, 12:24 AM   #1931
BrianDonegan's Avatar
Originally Posted by RH75 View Post
Would anybody know if it's possible to bypass the SRC in software mode?
(Hifiduinocode lists them,but not the "unused" one)
Kind of like PS Audio's NativeX,which totally bypasses the SRC and sounds better in this mode.
The datasheet should hold the answer...
Old 23rd February 2013, 07:00 PM   #1932
shoom is offline shoom  Europe
Hi Russ/Brian
Just finished my Teleporter/Opus/Ventus/Volumite HA/PRE build and I have to say it sounds very good indeed. (Yes Brian Iím the Brit who never manages to order everything in one go)
I have the Opus Dc coupled to the Ventus and the pre out section is isolated when I plug headphones in.
The ventus really bring my HD650 to life with the stock gain setting.
Iím going to have a listen with it as a pre next which will be interesting when compared to my Buffalo 3/Legato (look ma no caps)
Thanks for a great sounding kit at a very reasonable price.
Not a moan but a suggestion
I know that you must be busy but just a little snippet in the Manual about using the Opus in SW mode would be great.
I did find the answer on the support forum but was unsure if I had it right until the music flowed.
Just for others I have
I2S -0
And all the rest set to open(z)
Switch wise.
Thanks again
Old 6th April 2013, 04:57 PM   #1933
Hi All
A quick update
Whilst Iíve enjoyed the Ventus as a headphone amp driving my hd650 Iíve felt that it was slightly less successful driving my Audiosector chip amp.
So I ordered an IVY3 and wow it sounds superb.
It just seems to do a better job which is no real surprise I guess because thatís what it was designed to do.
Great work Russ/Brian Iím very happy with the Teleporter/Opus/IVY3/Volumite IT SOUNDS Awesome.
So now the Ventus gets its own box and works as a standalone Headphone amp so itís happy too.
Thanks again
Old 6th April 2013, 05:02 PM   #1934
Russ White's Avatar
Send a message via Yahoo to Russ White
Sounds like a nice setup! Enjoy!
Less pulp more juice Twisted Pear Audio.
Old 6th April 2013, 05:58 PM   #1935
And the big surprise is how close it gets to my Teleporter/Buffalo3/Legato.
Outstanding VFM
Thanks angain
Old 6th April 2013, 07:39 PM   #1936
Russ White's Avatar
Outstanding VFM
Thanks angain
I agree, I have long maintained that the Opus is no slouch. I still listen to mine regularly.
Old 25th April 2013, 04:32 AM   #1937
Default Ummm...
"Native" and "Native X" modes on the PerfectWave DAC do not bypass the oversampling of the Wolfson Chip. These modes bypass the asynchronous sample rate converter, which is a TI chip. Even in "Native" and "Native X" modes, the oversampling and filtering of the Wolfson DAC chip are still active. Indeed, it would probably be a bad idea to run a delta sigma DAC like the Opus with no oversampling. If you use the Opus without a Metronome, via an i2S source, you are running it in the same way as "Native" mode in the PerfectWave DAC.
Old 16th January 2014, 05:10 PM   #1938
Would the Amanero or the Wavei/o be a better usb to IS2 for the opus dac since the twisted one is not avail right now?
Old 16th January 2014, 07:16 PM   #1939
HAL2010 is offline HAL2010  United States
The Amanero board sounds really good with my Opus.
Old 27th January 2014, 11:58 AM   #1940
Hi All
I've just started my opus project. My plan is to make my opus dac modul working with amanero usb and play dsd and pcm stream also without mechanical switching.
Amanero has i2c tools. Is there a way to do it ? So when my foobar sends DSD data to amanero I want it to change mode to dsd on dac with modifying register value.
Certainly I've come across with arduino solution written on hifiduino's site but a bit confusing to me. First I just want the automatic switching.
thanks in advance
Karoly
Copyright ©1999-2017 diyAudio
