| Twisted Pear Superior quality electronic kits |
#1801 |
I'm not sure I understand why you would use an Ivy i/v stage after a Vout dac?
I assume its doing balanced to single ended conversion, but is an i/v stage not different to a buffer?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert |
#1802 | |
Really it is being used as a balanced filter and buffer with a BAL/SE stage for better common mode rejection. While it is a VOUT DAC, the output impedance is rather high. Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#1803 |
I checked around IC3, I reflowed the joints because they looked kinda crappy. I also looked around at all the joints, some not the greatest but seem ok.
I also checked what I could as far as correct parts. The only thing I question is R13, 14, 15, 16. according to the schematic they should be 2K for stereo and 1K for dual mono. As of now they are 1K. I don't know if this is a problem. Still the same result, no volume. The only reason I am not running dual mono is because I didn't know if I could just use + and G from balanced mode without hurting anything. As I am sure you could already tell I am a rookie at all of this, and I apoligize for being a dumb***. I am learnig very slowly. Only started with diy audio to keep my old brain more active with something I didn't know anything about. What's interesting to me is that I don't even get frustrated or p-off about any problems I have with electronics.(unlike my day job) ![]() Just another learnig experience. ![]() Jim
"This is DIY. I view op amps the same way I look at a can of soup or a fast-food burger" NP Last edited by max426; 13th June 2010 at 07:26 PM. |
#1804 |
What are your values for R 17-20?
#1805 |
they are 21 ohm
jim
"This is DIY. I view op amps the same way I look at a can of soup or a fast-food burger" NP |
#1806 |
thanks Russ, I want one now
#1807 | |
I will order a replacement and post results when replaced. Thanks again for pointing me in the right direction. jim
#1808 |
I would like to use 12 volt SLA batteries to drive the dac and the amp I use (Charlize). What do you recommend how to power the dac needing less then the 12 volts?
#1809 |
Hi, I've just gotten my Opus up and running and wanted to express my thanks to Twisted Pear and all those who posted questions and pics of their builds. I now need to get it into an enclosure with proper jacks but I tried it out by clipping the positive outputs and a ground to my headphones, and it drives them at a very nice level.
The most important parts: -It was easy to solder, thanks to the wonderful tinning. Thank you so much for that, I've assembled projects which caused a struggle along these lines, so what a breath of fresh air to find something which offers ease... -I didn't want to stop listening to music even though I was exhausted from a very long day. And I didn't want to skip to the next song; I was trapped listening to music, tapping my toes with a silly smile on my face. And this is before using it with speakers, or even testing it against other units...looks like a winner to me! Thanks again. |
#1810 |
Hi
I'm reading this thread and find the Opus dac and WM8804 receiver module very interesting. I've readed the WM8741 and WM8804 data sheet. But I'm not a digital gear geek. To help me to better understand the data sheet, I have questions. For the WM8804 in the data sheet, which pin number are for the AIFCONF1, TXS, AIFCON1, AIFCON0 ? And for the WM8741 in the data sheet, which pin number are for the I2S, DM1, DM0, MUTEB, MODE, IWO ? I found those setting, they are the standard setting for a Opus dac module with the WM8804 receiver module ? WM8804 RCVR AIFCONF1 - HI TXS - HI AIFCON1 - LO AIFCON0 - HI OPUS DAC I2S - HI DM1 - LO DM0 - LO MUTEB HI MODE LO IWO - HI All Others - Not Jumpered Thanx Paul Last edited by tessier; 4th March 2011 at 07:00 PM. |
| Page generated in 0.11052 seconds (64.59% PHP - 35.41% MySQL) with 11 queries |
