| Twisted Pear Superior quality electronic kits |
#131 | ||
Banned
#132 |
diyAudio Moderator Emeritus
Please explain why it won't do I2S directly, Ulas.
It's only audio |
#133 |
Ok guys (especially Jean-Paul) I hope this makes you happy.
![]() Thanks Max, and the rest of you for you help too. Notice the added optional VREGs(just jumper them if you don't need them) and the inverter for muting the DAC when there is a signal error. Also note the added small value resistors for the clock inputs. Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#134 |
Notice I don't have a pin header for "good signal" LED yet, just have not found a good place to put it yet....
#135 |
Dear Ulas,
No, it's true. I have not read it yet (not that I can fully understand it either). I will, as soon as I recover from my 24hrs guard... I'll try to understand if it can accept 16bit I2S, Philips format Dear Russ, You're welcome
Cheapest horn speakers: https://picasaweb.google.com/lh/phot...eat=directlink |
#136 |
#137 |
It seems I should connect the two ground planes. Maybe with a Ferrite/inductor and/or a small value resistor,
From WM8740 data sheet it appears that DGND and AGND must be at or very close to the same DC potential. So whats the best way? A simple resistor/jumper? Or Ferrite/Inductor? Or maybe both....
#138 |
I have had a few questions regarding the output. The WM8740 data sheet says that it can drive a load as low as 1K, so if you have a good high impedance stage after the DAC, you should not need any buffer. Even on the evaluation board you can bypass the output op amp circuit which in that case is not really a buffer, but a filter circuit.
My planned chain is this: DAC --> Joshua Tree attenuator(with about 4K worst case input impedance) -->Twisted Sibling balanced preamp (100K input impedance) --> Twisted X Overture balanced power amp(2.2K input impedance) --> various sundry speakers 4 and 8 ohm. Cheers! Russ
#139 |
Are you looking to do the AGND to VGND connection like on the eval board? It is a zero ohm resistor under the chip on the reverse side of the board.
#140 |
Russ,
Do you expect any problems with the variable input impedance of the JT on Opus? |
| Page generated in 0.12614 seconds (74.41% PHP - 25.59% MySQL) with 11 queries |
