| Twisted Pear Superior quality electronic kits |
#1301 | |
Thanks!! So no performance improvement, just mounting convenience? |
#1302 |
Correct.
Twisted Pear Audio |
#1303 | |
Have to redo the position of the 8804 and metronome boards I guesss. It is the highest freq. line from the 8804 board to the metronome that causes most problems. Even coming near with my finger kills the signal.
Kind regards, Bert |
#1304 | |
#1305 |
Kind of thinking about just getting an Opus for the time being. My question is what would be the more rewarding choice, going with dual mono DAC's or a single DAC with a Metronome? I'll be using the USB for now... so not sure jitter is AS big of an issue as if I was using it for a CDP. Eventually I will add the SPDIF module though. Also I might swap it out for the Sabre depending. I'm just getting a bit fedup with the sound from my sound card and not sure I can wait for the Sabre
Was also wondering do you think the COD is better then the Opus? Do you like the BurrBrown DAC better then the Wolfson? They are both oversampling yes? |
#1306 |
My personal thought is that metronome + 1 opus will be better than dual opus with no metronome.
#1307 |
I was thinking about buying the USB receivers to interface with a SAA7220+TDA1541A. I'm just not sure about the I2S output of the USB receiver. If it outputs in 24-bit I2S, will the SAA7220 still recognise the signal? Can I set the PCM2707 to output 16/44.1khz?
#1308 |
It is OK now, no noises or ticks anymore. wiring is super short and most psu lines are going under the plate. between 2 pcb's(which are on top of each other) there is a small screening plate, earthed.
#1309 |
#1310 |
Looks great
| Page generated in 0.12215 seconds (73.30% PHP - 26.70% MySQL) with 11 queries |
