| Twisted Pear Superior quality electronic kits |
#1021 | |
You just need the one PS nothing more. ![]() Just run a second set of wires to your second DAC, just like the diagram you posted is fine. You won't need to change anything power supply wise for the USB module. Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#1022 |
space charged
I have the SPDIF Rcvr>Met>Opus set up into an LM4562 preamp.
It had been playing superbly, then when turned on one day the system was giving out a low EEEEEE sound? Swapped equipment, still there. The noise plays thru regardless of which input I have selected? I disconnected power to the whole Opus board setup and the noise is gone. Any ideas. |
#1023 | |
I would need to know more about how you have it setup.
#1024 | |
space charged
So, I connected the Opus outputs directly to the output rcas and ran that into the My-Ref. Same thing, EEEEEEEE. Note, when going thru the Selector>VolCtl>PreampSection it made no difference whether the dac was selected? and the EEEE amplitude did not vary with vol setting? I'm going to change the setup to RCVR>OPUS leaving out the MET and see/hear what happens. The power supplies for the preamp and digital boards are separate and grounds connect at the volctl ground. This is very odd, as I've said it was playing fine the night before then WM8804 RCVR AIFCONF1 - HI All Others - LO OPUS DAC I2S - HI DM1 - LO DM0 - LO MUTEB HI MODE LO IWO - HI All Others - Not Jumpered MET ASRC AUTOMUTE Jumpered RDY Not Jumped OWL1&2 LO OFMT1 LO OFMT0 HI MODE0&1 HI MODE2 LO IFMT1&2 HI IFMT0 LO BYPASS HI All Others Not Jumped |
#1025 | |
IFMT1 : LO IFMT0 : HI Bypass : LO Is the way to go... --> you selected 20-bit right justified and then put the asrc in bypass mode... |
#1026 | |
space charged
Ooops! I posted those just the opposite of what they are. I did a quick look to post them and thought those jumpers (+)(-) were the same as the row on the left side. Now I see the (+) pins are all toward the center of the board. Anyway thanks for the response. |
#1027 |
And how eventually the USB module and spdif module can be connected to a switch. Please help with this. I am finally going to build this thing the weekend of the 22nd Thank you Darren |
#1028 |
Daren, just connect two sets of wires from the "DOUT" terminal block. One set going to each DAC.
#1029 | |
I guess if there were complete instructions for connecting in dual diff mode, I would be ok. I am currently compiling pictures, diagrams and instructions from all of the thread responses. All of your help has been greatly appreciated. Except that after looking at my "notes" and a pic of a setup from this forum, I see also that the output to the XLR sockets is not what I expected. As all of the terminals are used for each channel. With some of the wires joined. Could you please tell me the proper way to connect the DAC to the channels for dual differencial mode? Thank you for your help. Hopefully when all is said and done, I might be able to help others on this thread. Darren |
#1030 |
No worries Darren,
The opus manual covers some of the differential(mono) issues. The output terminals are switched a bit when you run that mode, so you have to check the polarity from the data sheet which is also in the manual. I will admit the manual is sparse. I will do what I can to help. This is a pretty advanced project,with a lot of elements still very much up to the builder. Cheers! Russ
| Page generated in 0.12573 seconds (85.30% PHP - 14.70% MySQL) with 11 queries |
