Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 5th December 2007, 07:11 PM   #1001
Send a message via ICQ to fierce_freak Send a message via AIM to fierce_freak Send a message via MSN to fierce_freak Send a message via Yahoo to fierce_freak
I've read that they're closer to 32-33 ohms. I forget the source, though.
Old 5th December 2007, 09:19 PM   #1002
analog_sa's Avatar
Default Re: Cheap easy wireless?
Originally posted by Russ White
I wonder if anyone has tried using a wireless video sender (2.4 or 5.8ghz) to transmit SPDIF.
I have thought about it, but not tried it yet.
That would be a cheap easy way to do multi room audio.
Cheers!
Russ
For casual lo-fi listening? It might work. These devices have around 18MHz bandwidth which means any serious fidelity is out. It's difficult enough to make coax cables sound ok...
Old 5th December 2007, 09:48 PM   #1003
analog_sa's Avatar
Originally posted by hbarki
Canare makes a 75-ohm RCA chassis jack:
http://www.canare.com/files/Cat11_p23.pdf
It has been previously discussed that these are not 75ohm in reality (outside the advertising brochures). The WBT NextGen are but only if used with corresponding male jacks. Somehow easier to use BNCs.
Old 5th December 2007, 09:49 PM   #1004
Russ White's Avatar
Send a message via Yahoo to Russ White
Default Re: Re: Cheap easy wireless?
Yeah, I had much the same thought.
Less pulp more juice Twisted Pear Audio.
Old 5th December 2007, 09:51 PM   #1005
Russ White's Avatar
easier to use BNCs.
Have to agree, if true 75 ohm terminations are your aim that's what I would do.
For short cable runs its very likely not going to be critical.
Old 5th December 2007, 10:30 PM   #1006
audiosteve's Avatar
You can use these to ship I2S across an Ethernet network.
http://www.atterotech.com/CobraNet-CO2-page.html
Nihilism is best done by professionals.
Old 5th December 2007, 11:00 PM   #1007
audiosteve's Avatar
In the interest of full disclosure, I should note that I am an employee of Cirrus Logic that makes the CobraNet chips that go into the CO2 boards noted in my previous post. However, I didn't make the post to try to promote a Cirrus product, just to inform about a technology that seems to apply to the topic. I would have done the same for any other product I was aware of that is on topic. Thought I should say this to keep things on the level.
Old 6th December 2007, 04:24 PM   #1008
Russ,
for the converter you built you made a nice relay board to switch between input modules. Any chance you would want to share the PCB layout and a parts list? I would like to expand my opus with a USB board and i would prefer such a relay board over a front panel switch.
By the way, i've been happily listening to my dual mono opus for a few days now, especially imaging is truly great.
L
Old 6th December 2007, 05:09 PM   #1009
AudioSteve please contact me offline about CobraNet. I've got a couple of questions at ... carl_dot_huff@yahoo_dot_com
Old 6th December 2007, 06:04 PM   #1010
BrianDonegan's Avatar
The board I used actually had an error on it (two of the I2S pins are reversed on the outputs). It also uses a relay that is not very common. We can probably redo it with something like G6H relays and fix the layout problem, then post it.
Twisted Pear Audio
Page generated in 0.11972 seconds (62.42% PHP - 37.58% MySQL) with 11 queries
