Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 11th December 2017, 04:12 PM   #81
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
Introducing Mercury - Achieving escape velocity.
Default Supply voltages, Mercury
I left the Placid voltage outputs the same as for the Legato I/V,
which is 15+ and 12-, as was once noted as best.
What's the recommendation for the Mercury.
https://www.youtube.com/watch?v=VCSayVA_3Cc
Old 11th December 2017, 10:36 PM   #82
Russ White is offline Russ White  United States
Russ White's Avatar
Rails from 12 to 15V will work fine. I recommend +/- 15V
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 12th December 2017, 12:41 AM   #83
cyrilliu is offline cyrilliu  Taiwan
Originally Posted by Russ White View Post
No it isn't
DC servo can only be used OP, capacitors or transformers to practice. In other words, DC servo is capacitors at Mercury?
Old 12th December 2017, 02:21 AM   #84
Russ White's Avatar
The servos are OPs. As usual
Audio
Introducing Mercury - Achieving escape velocity.Hide this!Advertise here!
achieving constant directivity as low as 200Hz using really large drivers? CharlieLaub Multi-Way 53 28th January 2016 11:28 AM
Unconventional Techniques for Achieving Oustanding Stereo Imaging Elias Multi-Way 415 17th February 2014 04:49 PM
Help achieving correct phase response in active 3-way setup pk Multi-Way 2 19th June 2010 09:13 AM
Escape from UK London Blast chris ma The Lounge 2 8th July 2005 06:36 PM
Copyright ©1999-2017 diyAudio
