Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 6th November 2017, 08:23 PM   #21
thomaspf is offline thomaspf  United States
Default Mercury and headphones
Since the IVY also can be used as a balanced headphone amp I wonder how the Mercury fares in this regard?
Cheers
Thomas
Old 7th November 2017, 01:31 AM   #22
Russ White is offline Russ White  United States
Russ White's Avatar
Cheers
Thomas
Exactly the same. You can use it like IVY-III in that respect.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 7th November 2017, 02:07 AM   #23
If you have it at the top of your mind...
Can you remind us what the drive capability of the IVY at 16, 32, and 300 Ohms was.
Cheers
Thomas
Old 7th November 2017, 11:34 AM   #24
Russ White's Avatar
Really as long as you live within the confines of the OPA1632 datasheet you will be just fine driving any headphone. The absolute max output current of the OPA1632 is 150ma - I would never try to push it much beyond 100ma though - so you just have to plan based on your intended load. For high impedance cans I give myself some extra voltage gain - for low impedance cans I sometime reduce the gain but usually leave it alone. If your cans need more than 100ma or so then I would use a separate headphone amp. I only have a couple of pair that need more - and they are special cases.
Audio
Old 22nd November 2017, 01:48 AM   #25
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Introducing Mercury - Achieving escape velocity.
I just opened up pre-orders for v1.0, which will begin shipping the week of Dec 4th.
This is a picture of the jumper that needs to be added for the right-channel balanced output (about 12mm long):
Introducing Mercury - Achieving escape velocity.-jumper-jpg
Old 22nd November 2017, 07:47 AM   #26
wealas is offline wealas
It's out of stock already?
Old 22nd November 2017, 07:56 AM   #27
Nvm, it shows up in stock if you wait a bit and refresh.
Old 23rd November 2017, 07:57 AM   #28
Dimdim is online now Dimdim  Greece
Instead of adding a jumper (which is a totally valid solution as well IMHO..) you could just scrape the green solder mask over the ground plane next to the ground pin and use a blob of solder to make the connection.
http://www.dimdim.gr
Old 23rd November 2017, 11:45 AM   #29
Russ White's Avatar
Indeed you could! We just thought the jumper method was easier for most folks to execute. Either method is fine.
Audio
Old 23rd November 2017, 11:52 AM   #30
Russ White's Avatar
Originally Posted by cyrilliu View Post
When will the Version 1.1 of the Mercury be purchased?
I'm worried that adding a 12mm jumper at the right-channel balanced ground will cause unbalance between the left and right channels, affecting sound quality. If jumpers are added to both left and right channels, the problem is smaller.
No - the jumper absolutely wouldn't effect quality Balanced signals don't work like that. GND is not really part of the signal for a balanced output - all that really matters is that the shield has a single path back to GND.
In any case - 1.1 boards are ordered but it will probably be a couple of weeks before they are ready - in the meantime I would not let the jumper stop you.
Cheers!
Russ
Audio
Introducing Mercury - Achieving escape velocity.Hide this!Advertise here!
achieving constant directivity as low as 200Hz using really large drivers? CharlieLaub Multi-Way 53 28th January 2016 10:28 AM
Unconventional Techniques for Achieving Oustanding Stereo Imaging Elias Multi-Way 415 17th February 2014 03:49 PM
Help achieving correct phase response in active 3-way setup pk Multi-Way 2 19th June 2010 08:13 AM
Escape from UK London Blast chris ma The Lounge 2 8th July 2005 05:36 PM
