Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 25th May 2018, 10:20 AM   #591
Luke is offline Luke  New Zealand
Introducing the Buffalo III-SE-Pro 9028/9038 Send a message via AIM to Luke
I've heard the Devialet, but not the hifi Berry or the Allo Piano. My Buffalo was a big step up from my Audiolab cdq8200 and opus dac. Nice build btw, although I liked the cardboard box
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 25th May 2018, 12:26 PM   #592
Russ White is online now Russ White  United States
Russ White's Avatar
Originally Posted by Claire Fox View Post
My previous DAC was a Devialet D200 but I really felt it’s proprietary nature was worrying for the future and I went back to valves anyway because I like the sound more. I then got a HiFiBerry DACPro (the balanced one, didn’t like that at all) and then tried an Allo Piano 2.1 with Kali and Isolator, better. Am going to keep the Piano on its own for another Kodi installation and as a reality check about just how far forward this dac it is and move the Isolator with the Kali with touch screen and Volumio for an open ended dac solution.
Last night, had the touch screen working with Kali just before I broke the 1.2V vreg (oops) I am a bit clumsy and at the edge of knowing exactly what I am doing, but it’s all good learning stuff...
Nice work! Your layout is solid. I hope you get a lot of enjoyment out of it.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 25th May 2018, 02:53 PM   #593
Claire Fox is offline Claire Fox  United Kingdom
Claire Fox's Avatar
Thank you, I am not an expert like a lot of people here and I am breaking things and mis-setting things because I stay up too late and push too many changes at once. It sounded just phenomenal though, my goodness Propellorheads Decksanddrumsandrockandroll was just laid completely bare and things submerged in the soundfield became crystal clear... Blur’s Think Tank has a lot of recordings of things in other rooms that you can hear so easily now and it sound like it’s in another room and not a recording of another room — if that makes sense and Plaid’s Rest Proof Clockwork is a deep dive into sampled details that is just hash on lesser DACs....
It was all working just fine until I added the Isolator and the touch screen then it started to distort and only on one side, distorted, the Placid started doing weird things like outputting 15v on the - side and just 8V on the + side, but unhooking the 1.3 regulator brought both sides back to +/-15V I think I messed things up settings wise on the dip switches again and then taking reading from the 1.3v regulator there was a little snap and the magic smoke came out...
I briefly hooked up a 1.3V regulated supply from a LCDPS (briefly, that a lot of heat to shunt) just to be sure the DAC light blinked on and locked and after that just ordered another regulator...
Up late, get sleepy, try to push too fast, the result is getting into a tangle... hopefully I can solve the problems and get this safely in its case before too long.
Old 25th May 2018, 03:36 PM   #594
MartinC700 is offline MartinC700  United States
Originally Posted by JoeyDD View Post
I finally got the modified firmware on a new ATtiny85 (somehow I managed to brick or fry the original since couldn't even reset the fuses with HVSP).
I can confirm that modifying the firmware as in post #511 results in having both PCM/DSD in "pure sync" mode and SPDIF in async mode. It works well using the original method of switching between the two inputs.
In pure sync mode I can echo what Twluke and Fedor have already said: the sound is more open and lively while remaining "full bodied". Sounds very good! The only issue I have is that with DSD512 I get a high pitched constant noise superimposed on the music, and only in the right channel. Changing back to DSD256 the noise completely disappears. Not sure if this could be a firmware issue, or any of the other parts that come before the buffalo?
As for the pop on pausing the music, I cannot reproduce it, but maybe it's because I have the Buffalo hooked up to the NTD1 which has coupling caps on the output?
Paul
Hi Paul,
I was wondering if you could provide some guidance on what you used to program the ATTiny ? I have the chips and the programming board and successfully configured the Arduino IDE to program the chip with the test 'blink' program.
My issue is now how to take Russ' files, make your modifications and then compile to a hex file and load to the ATtiny.
I assume that I would use AVRDude to send the program to the chip, but am unsure what is the best IDE for working with Russ' files from GitHub?
Any advice would be much appreciated.
Old 25th May 2018, 04:39 PM   #595
JoeyDD is offline JoeyDD  Canada
Hi Martin,
What I did was that I downloaded the Master Sync Mode files from GitHub and then used them to create a new project using AVR Studio. I modified the the buffalo.c code and then built the program to get the hex file.
To program the ATTiny I first tried using and old Atmel AVR ISP programmer that I had (modified so that I can also power the ATTiny), but just couldn't get it to work. The alternative solution was a spare RPi3 running Raspbian and AVRDude. The ATTiny was plugged into a breadboard and connected to the RPi3's GPIO. I connected to the RPi3 via SSH and used terminal to program the ATTiny with AVRDude on the RPi3. It worked perfectly. You can have a look here: Overview | Program an AVR or Arduino Using Raspberry Pi GPIO | Adafruit Learning System. It explains step by step how to set everything up and then program using AVRDude.
Paul
Old 25th May 2018, 05:16 PM   #596
Hi Paul,
Thank you for the very thorough information, much appreciated, it will be a great help.
Old 26th May 2018, 02:52 PM   #597
Hi Paul,
Almost there - the only issue now is that for some reason AVRDude refuses to change the high fuse to 0xF5, it gives:
avrdude.exe: verifying ...
avrdude.exe: 1 bytes of lfuse verified
avrdude.exe: reading input file "0xF5"
avrdude.exe: writing hfuse (1 bytes):
Writing | ***failed;
################################################## | 100% 0.06s
avrdude.exe: 1 bytes of hfuse written
avrdude.exe: verifying hfuse memory against 0xF5:
avrdude.exe: load data hfuse data from input file 0xF5:
avrdude.exe: input file 0xF5 contains 1 bytes
avrdude.exe: reading on-chip hfuse data:
Reading | ################################################## | 100% 0.00s
avrdude.exe: verification error, first mismatch at byte 0x0000
0xd5 != 0xf5
avrdude.exe: verification error; content mismatch
The other fuses set fine and the program loads - at a bit of a loss here.
Old 26th May 2018, 03:33 PM   #598
Checking further the high fuse will set to other values, so it looks like the programmer wont accept the 0xF5 value which compared to the 0xD5 disables SPI on the chip. Looking at the datasheet the high fuse setting disabling SPI cannot be changed if the TinyAVR programmer is using SPI mode to program. I guess I will have to use another programmer to set that fuse.
Old 26th May 2018, 04:16 PM   #599
twluke is offline twluke  Japan
Originally Posted by MartinC700 View Post
-snip-
0xd5 != 0xf5
To avoid this verification error, you might want to try to add a 10K R between Vcc and Reset and a 0.1uF C between Vcc and GND.
Old 26th May 2018, 04:39 PM   #600
Thanks I will try that but I think the issue is more fundamental and that the chip wont accept a fuse value that disables SPI when being programmed via SPI, the datasheet states the fuse byte high (SPIEN) is not accessible when programming with SPI. I guess a question for Russ is whether a setting of 0xD5 (which enables the same chip settings with the exception of not disabling SPI) would work.
Introducing the Buffalo III-SE-Pro 9028/9038Hide this!Advertise here!
WTB Twisted Pear Buffalo II or Buffalo IIIse charliecola Swap Meet 4 10th September 2016 06:13 PM
WTB : Buffalo III or Buffalo IIIse pw8888 Swap Meet 0 29th March 2015 09:06 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
Technics ST 9038 Op amps modification Robert64 Analog Line Level 5 21st August 2005 12:11 AM
Technics SH 9038/ST 9038 audio-kraut Analogue Source 0 2nd July 2005 01:53 AM
