Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 15th October 2017, 12:57 AM   #21
diyaudnut is online now diyaudnut  United States
Looking forward to this.
My wishlist is
USB multichannel interface +
Ian's MCFIFO +
Buffalo IV 8CH
Old 15th October 2017, 01:10 AM   #22
akras is online now akras  United States
Originally Posted by Russ White View Post
We are aiming for the next few months. There is a close cousin to Mercury planned for 8 channel use. Mercury could be used - but there is a more efficient solution.
Cheers!
Russ
Looking forward to the 8-channel version. It would be nice if the DAC input were directly pin-compatible with the output of Cronus... Any chance of this happening?
Thank you,
Andrey
Old 15th October 2017, 06:26 AM   #23
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Introducing the Buffalo III-SE-Pro 9028/9038
Ups I ordered a Legato together with the 9038. I did not regognize the New Mercury. Something possible to change?
Old 15th October 2017, 08:49 AM   #24
ENSen is offline ENSen  Sweden
Order placed!
Old 15th October 2017, 09:42 AM   #25
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
Looking to upgrade my Buffalo 3SE to the new 9028 board, retaining my Legato (at least for now) but also need to ensure the power supply arrangements upstream of the Tridents could cope with the upgrade.
The website states power requirements as '5.0VDC @ 750mA for powering onboard regulator' - is that for both the 9028 and 9038?
I currently use a Salas Reflektor-D shunt regulator to power the Buffalo 3SE board but that seems to have a maximum current capability of 600mA so probably a stumbling block.
Old 15th October 2017, 12:01 PM   #26
An modified Legato solution would be Nice.
Old 15th October 2017, 07:51 PM   #27
Russ White is offline Russ White  United States
Russ White's Avatar
Thank you,
Andrey
Cronus input will definitely be at the top of the list.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 15th October 2017, 07:52 PM   #28
Russ White's Avatar
Contact Brian - he can adjust the order for you if you like.
Audio
Old 15th October 2017, 07:56 PM   #29
Russ White's Avatar
The 9038 uses more current than the 9028.
Yes you will definitely want a supply capable of delivering more current than that.
We have a new version of the LCDPs that uses new lower noise regulators that can deliver up to 2A with proper heatsinking. That is what I am using right now - because it's nice not to have to adjust for maximum current and then just waste current most of the time
I strongly recommend people consider using the new LCDPS - especially if you use Cronus. Power the Cronus with one side and the Buffalo with the other.
Cheers!
Russ
Audio
Old 15th October 2017, 08:07 PM   #30
bk856er is offline bk856er  United States
bk856er's Avatar
How new is the new LCDPS and is more information available? I believe mine is v1.1 from a few years back.
BK
Introducing the Buffalo III-SE-Pro 9028/9038Hide this!Advertise here!
WTB Twisted Pear Buffalo II or Buffalo IIIse charliecola Swap Meet 4 10th September 2016 06:13 PM
WTB : Buffalo III or Buffalo IIIse pw8888 Swap Meet 0 29th March 2015 09:06 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
Technics ST 9038 Op amps modification Robert64 Analog Line Level 5 21st August 2005 12:11 AM
Technics SH 9038/ST 9038 audio-kraut Analogue Source 0 2nd July 2005 01:53 AM
