Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 14th October 2017, 08:35 PM   #11
Russ White is offline Russ White  United States
Russ White's Avatar
Originally Posted by Greg Stewart View Post
Very interesting.
Order placed.
When will we hear more about the Mercury I/V & better yet, be able to order them?
TIA.
Greg in Mississippi
Thanks! I will post more about Mercury as soon as the production boards are tested. It (Like the IVY-III) is based on the OPA1632 and has three stages - the first stage being a very high current transimpedance amplifier stage. It also has two servos that play very important roles. I won't go into more detail than that just yet.
Literally as soon as I have the boards and parts in my hands and I can test that the production boards are good to go - we will make it available.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 14th October 2017, 08:37 PM   #12
Russ White's Avatar
Originally Posted by stefanhgm View Post
Congratulations for your awesome work!
PS: Preorder already placed to ensure getting hold of one
Thank you! And very wise based on past experience.
Contact Brian about the order - I am sure he can work something out for you.
Cheers!
Russ
Audio
Old 14th October 2017, 08:42 PM   #13
thomaspf is offline thomaspf  United States
Congrats, I am heading to preorder right now!
Old 14th October 2017, 08:50 PM   #14
barrows is online now barrows
Default Sweet!
Hi Russ, already ordered a 9038 board, so glad it is here! It sounds like you are quite excited about the Mercury I/V, so am I really happy about that, as I/V stage is probably more important than the chip to SQ these days...
I hope the Mercury can be configured for both 2 and 4 volt output (balanced) as I sometimes use amps with 26 dB gain and huge outputs (like Ncore 500 and 1200 modules) which need >2 V in to achieve full output.
Old 14th October 2017, 11:02 PM   #15
Russ White's Avatar
3) Is it somehow possible to get back an 8 Channel output from a BuffaloIIIse Pro? (Sorry if that's a dumb question, I'm pretty new to the material)
4) I'd like to feed the BuffalloIIIse Pro with a BBB. Just to be sure, the BuffalloIIIse Pro is compatible with the Hermes-BBB and Cronus Re-clocking module? So, a "Buffalo-IIIsePro38" Kit (w/ regulator and power supply), a "Hermes-BBB Isolator Module" and a "Cronus Re-clocking Module with 45.1584/49.152MHz Rhea Pair" is all I need for a complete build fed by a BBB?
Thanks!
I forgot to answer these two questions.
3) No - not unless you used 4 of them
4) Absolutely - it works very well with Cronus/BBB or Cronus/Amanero etc. Really just about any DSD/I2S source.
Audio
Old 14th October 2017, 11:07 PM   #16
Russ White's Avatar
Thanks Barrows!
Indeed - Mercury is my new pride and joy. I am really excited about it. You are right - without an I/V to match it - there is no reason to use the ES9038 other than using it like 4 ES9028/18
You absolutely can adjust the Mercury balanced and/or SE output easily to 4V - even more. The limit is really just the limit of the OPA1632 and the rails. As long as your input impedance is > 1K or so even 10V out should be doable.
Cheers!
Russ
Audio
Old 14th October 2017, 11:34 PM   #17
twluke is offline twluke  Japan
Introducing the Buffalo III-SE-Pro 9028/9038
Originally Posted by Russ White View Post
Hi Russ, many congratulations for this great notification! I've just ordered both of ES9028 ans ES9038 boards.
It's been quite a while since many ES9038 DACs had been introduced in the market of audiophiles but I'd like to appreciate your great patience long kept for this final announcement with many preliminary tests to offer well designed, sophisticated DACs to the end users like me.
BTW, did you solve the problem of chip to chip output differences (up to 28% difference?) with ES9038, that would make dual mono setting difficult? Maybe the coming Buffalo IV with 8 channels may give an answer to it.
Best Regards,
Old 14th October 2017, 11:48 PM   #18
diyaudnut is offline diyaudnut  United States
Russ,
any comments on 8ch availability? I am interested in one for my active 4way.
Is mercury also the optimal solution for 8CH mode?
Old 15th October 2017, 12:06 AM   #19
Russ White's Avatar
Best Regards,
Thank you!
Yes! It can be solved via the auto gain calibration feature. This allows chip to chip matching of gain. Our firmware is open source - and I am updating it for mono mode - when I do I will enable gain calibration as well. The new DAC board has all of the components required (especially the reference resistor) to do the calibration.
Also of critical importance - the on-board firmware correctly dictates the power on reset condition these new chips require as well.
ESS did a great job with these chips - the chip to chip gain difference has always existed (even in the ES9018 etc...) but now people can actually do something about it.
Cheers!
Russ
Audio
Old 15th October 2017, 12:09 AM   #20
Russ White's Avatar
Originally Posted by diyaudnut View Post
Russ,
We are aiming for the next few months. There is a close cousin to Mercury planned for 8 channel use. Mercury could be used - but there is a more efficient solution.
Cheers!
Russ
Audio
Introducing the Buffalo III-SE-Pro 9028/9038Hide this!Advertise here!
WTB Twisted Pear Buffalo II or Buffalo IIIse charliecola Swap Meet 4 10th September 2016 06:13 PM
WTB : Buffalo III or Buffalo IIIse pw8888 Swap Meet 0 29th March 2015 09:06 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
Technics ST 9038 Op amps modification Robert64 Analog Line Level 5 21st August 2005 12:11 AM
Technics SH 9038/ST 9038 audio-kraut Analogue Source 0 2nd July 2005 01:53 AM
