Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 28th July 2017, 11:19 AM   #41
C37 is offline C37  Belgium
Another Noob question, i am using Pure Music on my mac and i see it can stream up to up to 192 kHz / 24 bit over Lan see this pdf. Could this stream be used by BBB Botic+TP reclockers so i have access to more than 2 channel I2s or is there some Mac/Linux incompatibilities meaning I'm screwed?
Edit It's actually: " Uncompressed local audio streaming support with NetSend (up to 384 kHz and up to four separate connections)"
Ohm sweet ohm
Old 31st July 2017, 07:25 AM   #42
miero is offline miero  Czech Republic
there is a "shairport-sync" software that can receive AirPlay stream on Linux ... no idea if it works with multichannel audio
try Volumio image for BBB ... it should be integrated here ... maybe it must be enabled first in config, I'm not sure
is Pure Music compatible with AirPlay? if not, then this will probably not work...
BeagleBone Black with I2S, DSD and SPDIF interface (Linux driver)
http://bbb.ieero.com/
Old 31st July 2017, 07:14 PM   #43
Looks like i'm screwed for streaming from Pure music over LAN- requires mac developper tools' AU Lab at the receiving end. As for Airplay, it's supported , yes i read it that on paper it does 5.1 but i also see it downsamples everything to 44.1/16 - I'm still digging- Pure music support is on holidays now. Awww god- airplay can work over ethernet it seems - My head is going to explode...
Ohm sweet ohm
A multi-channel interface from PC - the Missing LinkHide this!Advertise here!
Multi-channel digital audio link, new standard? mhelin Digital Line Level 1 1st February 2016 03:16 AM
Multi-channel PC audio interface - options? error401 Digital Source 6 5th March 2008 10:32 AM
High Resolution Multi-Channel Digital Interface Brian Brown Digital Source 34 15th January 2008 06:48 PM
