Which Pass Amp ? - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 17th August 2015, 11:28 PM   #1
cowboy99's Avatar
Default Which Pass Amp ?
When considering doing a multi-channel BIII build, the question of which Pass power amp would work best with it in multiple output pairs needs consideration.
I've acquired almost all the pieces, BIII , the other TP modules, all various power supply, etc for a multi- or dual-mono. BUT...I intend to follow Russ's advice and "keep it simple at first with a stereo version"... to learn the DAC well before jumping into 4 or 6-channel (w/2 or 3 BIIIs) or dual-mono (w/2 BIII's).
I 'HAVE TO' at least swim in the multi-channel waters..... but can foresee Dual-Mono as a actually better trade-off.
OK, what have I not considered before I begin THE BUILD ?
Maybe, .... What the hell do I intend to feed all this to ? The Output power stages need to be flexible/expandable with common building blocks with each 2X channel increase.
Once I thought... Pass F5, even F5Tc. No! What a pain-in-*** 6ch bias beast that would be.
F4 - Ahh, its a DAC build, not a gain stage. And no, I'm not interested in using chip amps or class D !
With its stability, high input impedance (240K)...... even a sensitive 'glass' pre- would enjoy it.
A regular Joe, yet Class A ?
The Pass Aleph J seems to be a great choice ( but I could be wrong). Would not have to think of building a 4 or 6 channel J-amp. Believe I could simply add separate 2-channel stereo units. Common grounding may be big issue and possibly necessitate 'balance mode'.
So, long story short:
What do you think of Aleph-J power, feed by a Buffalo III DAC 2-6 channel ????
Charles
I'm kinda curious about that myself........
Last edited by cowboy99; 18th August 2015 at 04:40 PM. Reason: Too long winded, didn't get real question addressed
Old 18th August 2015, 03:08 PM   #2
BrianL is offline BrianL  United States
First off, fix your font. Secondly, I'm not sure what the point of this question is. This DAC setup is by all accounts a good DAC. It should drive any reasonable amp.
bel
Old 18th August 2015, 04:47 PM   #3
cowboy99's Avatar
Sorry about that, ... didn't get my question across well with all the chatter and beer. I edited post
Old 18th August 2015, 09:35 PM   #4
Russ White's Avatar
Send a message via Yahoo to Russ White
I like the Aleph's a lot - Aleph-X or Aleph-J would be solid choices. As is Sympatico. As BrianL said - you won't have a hard time finding a power amp to match the B3 with IVY-III.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 19th August 2015, 02:35 PM   #5
cowboy99's Avatar
Thanks Russ,
Just can't seem to focus on one component without considering the whole package. I like the J with its moderate output. With possible 6-ch, anything over 50W x 6 seems excessive.
If/When 6ch becomes my goal its apparent that 3 BIII's would be the best route. I'll take em one at time though
Charles
Old 19th August 2015, 02:43 PM   #6
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
you can use upscaled* power amp (Aleph J ) for bass and downscaled** for mid and tweet
*both PSU voltage and Iq , comparing to regular FW iteration
** just Iq , comparing to regular FW iteration
if you end up having any particular question about Aleph J , ask in PL subforum
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th September 2015, 07:34 PM   #7
in making the choice between 2 mono DAC channels or multi-channel, I think the crossovers deserve attention. I'm doing multi-channel because I never was 100% happy with my DIY passive crossovers. The best passive solution I found was at line level, but upgrading to a balanced signal chain pushed me to active crossovers, which are preferred.
Re the Aleph J, when I first heard the quality of the discrete Legato I/V, I was so impressed that I decided to build an Aleph J for mids & highs. The Aleph sounded great, but did not mix easily with my other amps so unfortunately it is idle.
ZM's suggestion for a modular approach makes sense, but how to nicely match the channels? Would it be possible to develop one fully differential front end that would drive a variety of different 10X power stages (maybe including Pass-inspired boards available from the DIY Audio store)? That way one could use discrete & class A components where they really shine, and other power circuits where class A is just too hot or unwieldy. ...a differential front end like a discrete version of the old TXD circuit? Perhaps making that work for kit-preferring end users is a lot to ask!
Cheers!
Old 1st October 2015, 01:06 AM   #8
Default is amp the real Q?
I have B-II / Ivy-III balanced direct to PL XA100 monos for mids/tweets (passive xo), & unbalanced outputs from B-II through active xo to (non-PL) high-current amp for bass.
I tried active xo for mids/tweets as well, but prefer the sound of the passive xo.
Point is, the Q is not just which amps, but what xo & speaker-driving topology to use, & how to integrate sound through xo region if bi or tri-amping.
Solar-powered everything...
Old 4th November 2015, 01:58 AM   #9
cowboy99's Avatar
Have to agree somewhat with trying options for modular, bi/tri-amping XOs mentioned in 3 previous posts ...Thanks. Again, the options seems almost exponential.
My actual 'building' has been delayed by recent speakers I've accquired by dumb luck.
Picked up a nice pair of Boston Acoustics T1030 towers with biamping option. A week later inherited a almost new (unused/stored for 20+ years) pair of Boston Acoustics T1000......unbelievable ! Not SOArt, but perfect for modular XO setup.....
So fate is making decisions for me.....works for me, seeing how I can't make up my own mind.
I can see an amp atop each one of these towers maybe with PSUs in a bottom pedestal....
Each tower self contained feed by common source/DAC/Pre
Charles
Old 10th November 2015, 05:59 PM   #10
I'm driving F5 with Buffalo IIIse+Legato 3.1 directly and even with it's stock 1.5V i'm usually half turn of the volume with my 95db speakers. With less efficient stuff at friends systems i often have to go to 100% so mybe one day i'll mod legato outputs to 2V...
Sympatico is a great amp too. Using it in the summer, and class A for the winter
Pass Labs amp combination for Thiel speakers, need Mr Pass' advice ! And everyone... JulienG Pass Labs 82 6th July 2015 02:41 PM
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
best pre amp for pass aleph 5 & beginning builder! Paulus1981 Pass Labs 5 4th April 2006 03:10 PM
Amperes of Pass amps & Pass for ESL rick57 Pass Labs 3 4th August 2005 03:28 PM
Pass & Bender Rebuild Plans for Cit 12 Classic Audio Solid State 1 24th December 2003 10:14 PM
Copyright 1999-2017 diyAudio
