Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 16th May 2015, 10:43 PM   #21
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
BBB/Botic/Cape play problem
Originally Posted by Russ White View Post
Check all the solder joints on the Rhea in X1 (the one for 44.1K) retouch if necessary
Will do!
Currently listening to F4 or F6/w curve matched SemiSouth outputs
Old 16th May 2015, 10:53 PM   #22
ichiban's Avatar
Where to solder/check?
Old 16th May 2015, 11:01 PM   #23
ichiban's Avatar
The 49MHz Rhea does look shinier in comparison. This is tiny work will it hurt if I I get a some what big glob on it or should I just reheat with tip?
Old 17th May 2015, 12:58 AM   #24
ichiban's Avatar
Touched up Rhea 45MHz clock, flashed up to Bot-5 and YES!!!
44k1 files play!!!
Greatfull thank yous to all who suffered through my missteps and
helped me out.
Old 17th May 2015, 01:19 AM   #25
Russ White is offline Russ White  United States
Russ White's Avatar
No worries - very glad to help.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 17th May 2015, 04:51 PM   #26
Russ White's Avatar
Ichiban - It would be nice if you might post on the Botic thread - just to close the loop so people know that you have your issue resolved.
I hope you are enjoying the music!
Cheers!
Russ
Audio
Old 17th May 2015, 08:04 PM   #27
ichiban's Avatar
Will do.
Yes, enjoying the music, as long as MPD co-operates. Never a dull moment!
On the sound quality, I find it removes a veil I didn't know was there when using Linux/Mint USB out to a USB2I2S converter onto the BII. In other words I like.
Old 17th May 2015, 08:56 PM   #28
Russ White's Avatar
Excellent! Glad to hear it.
Cheers!
Russ
Audio
Old 1st June 2015, 05:08 PM   #29
zz1969 is offline zz1969  Russian Federation
OK, I have installed Squeezelite but I'm not sure I understand how to play DSD (dsf/dff) files. My LMS 7.7.5 just does not see those files. I'll be grateful if someone will enlighten me or link me to where I can read about the subject.
Old 1st June 2015, 05:26 PM   #30
bern is offline bern  Poland
to play DSD/DSF files you need v7.9 of LMS. See 7.9 LMS changelog:
GitHub & BitBucket HTML Preview
Some Software Beta Downloads - Version 7.9
BBB/Botic/Cape play problemHide this!Advertise here!
Support for Botic Linux driver miero Twisted Pear 2479 25th May 2018 06:15 PM
Hermes-BBB/Botic cape for BeagleBone Black Russ White Twisted Pear 595 19th March 2018 02:37 PM
BBB + I2S + DAC odem81 PC Based 7 6th January 2015 05:10 AM
Slaving BBB to Buffalo III, possible? giulio Twisted Pear 5 11th December 2014 09:47 PM
Problem getting RX-V2500 to play nice with SACD DVD-A Player sumsound Everything Else 0 27th August 2008 05:03 AM
