Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 16th May 2015, 09:50 PM   #11
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
BBB/Botic/Cape play problem
Originally Posted by Russ White View Post
It is hard to say from the pictures - but some of the solder joints on both the hermes and bbb headers look like they could use a touch up with flux - they don't look like they have flowed well to the pads - some look like they could be a dry joint.
Gave all connections a hit. Still no go. I'm on Bot3 will go to Bot5 again, just for laughs
Currently listening to F4 or F6/w curve matched SemiSouth outputs
Old 16th May 2015, 10:13 PM   #12
Russ White is offline Russ White  United States
Russ White's Avatar
Try switching sample rates between 44.1 and 48
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 16th May 2015, 10:16 PM   #13
ichiban's Avatar
How do I do that? Switch hardware clocks?
Old 16th May 2015, 10:17 PM   #14
Russ White's Avatar
You could try that too - but I just meant play 44.1 material and say 48khz or 96khz material. So that you test both clocks.
Audio
Old 16th May 2015, 10:27 PM   #15
ichiban's Avatar
Son of a gun!!!!!!!! Music from Mieros test files that he has on Bot3 but as far as I know aren't on Bot5.
Now I have the 45mHz clock in the outboard position which is E1, no?
Old 16th May 2015, 10:30 PM   #16
ichiban's Avatar
Oh! The test_96k_24b.flac file doesn't play?
/data/test/test_48k_16b.flac does play???
Maybe something that was in Bot3 that doesn't switch right?
Old 16th May 2015, 10:34 PM   #17
Russ White's Avatar
Yes - X1 is for the 44.1 ratio clock (45Mhz in your case)
Audio
Old 16th May 2015, 10:35 PM   #18
Russ White's Avatar
16 vs 24 bit should not matter at all.
Try 44.1 multiple material too.
Audio
Old 16th May 2015, 10:37 PM   #19
ichiban's Avatar
No, test_44k1_16b.flac
doesn't play, none of my 16bit 44k1 cd rips did either.
Old 16th May 2015, 10:39 PM   #20
Russ White's Avatar
Check all the solder joints on the Rhea in X1 (the one for 44.1K) retouch if necessary
Audio
BBB/Botic/Cape play problemHide this!Advertise here!
Support for Botic Linux driver miero Twisted Pear 2479 25th May 2018 06:15 PM
Hermes-BBB/Botic cape for BeagleBone Black Russ White Twisted Pear 595 19th March 2018 02:37 PM
BBB + I2S + DAC odem81 PC Based 7 6th January 2015 05:10 AM
Slaving BBB to Buffalo III, possible? giulio Twisted Pear 5 11th December 2014 09:47 PM
Problem getting RX-V2500 to play nice with SACD DVD-A Player sumsound Everything Else 0 27th August 2008 05:03 AM
