Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 18th June 2018, 11:21 PM   #141
barrows is offline barrows
Default Update
After loading the device driver, I had no problem flashing the configuration bits. So i have successfully got amanero running:
slave for 1080
1099c
and config bits as shown in Russ' post on page 1
Now my linux player software shows it is working with native DSD 256, but still no lock on the DAC (also tried direct USB from Mac with various sample rates, no lock on anything).
Not sure what the problem could be other than broken Amanero (or DAC?)
This entire build was working perfectly before trying to change the Amanero firmware, so not much to check...
I will check the DAC with an alternate interface, then purchase new Amanero/Hermes??
Old 19th June 2018, 01:12 AM   #142
twluke is offline twluke  Japan
Introducing the Hermes-Amanero
slave for 1080
1099c
Did you try to connect your Amanero directly to the DAC without Hermes/Cronus (i.e. with standard flash using CPLD_1080)?
Old 19th June 2018, 04:10 PM   #143
Russ White is offline Russ White  United States
Russ White's Avatar
Yep - that's the next step - is to just try the amanero in master mode. If it isn't working that way - it's damaged.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 19th June 2018, 06:25 PM   #144
Default Yep...
Will do. I tested the DAC with another USB interface to be sure, and it is fine.
Introducing the Hermes-AmaneroHide this!Advertise here!
Hermes-BBB/Botic cape for BeagleBone Black Russ White Twisted Pear 595 19th March 2018 02:37 PM
WTB: amanero board janos_904 Swap Meet 7 10th May 2015 10:50 AM
WTB: Amanero ristar Swap Meet 5 5th December 2014 07:55 AM
amanero merlin2069er Swap Meet 3 19th April 2014 09:32 PM
WTB - Amanero ThuyTN Swap Meet 0 31st January 2013 10:21 AM
