Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 16th May 2017, 12:01 PM   #541
Kanutus is offline Kanutus
Originally Posted by grael View Post
For the DDDAC, you need Bitclock (BCK), Left Right Clock (LRC) and DATA. And Ground.
With your DDDAC mainboard, you should have received a short female/female ribbon with 10 pins headers.
On the Cronus, I use the "B3" header, with male headers pointing UNDER the Cronus board.
Only the 3 used signals on one side, and the 5 ground pins on the other (check the first attachment)
This way, you can connect the ribbon like on the second attachment.
I hope it's not too obscure
Perfect! I'll work with this ...
Old 16th May 2017, 12:04 PM   #542
By the way, what do you mean with those questions:
Cronus is synchronous in its principles...
It is the clock master, feeding a slave source, reclocking on the same master clock then feeding a slave DAC (which DDDAC is).
Not sure what you were asking here
No, me neither (not knowing what I'm asking), but I have seen 'discussions' on whether to go with synchronous or asynchronous connections from Cronus to dac. But I'm happy with your answer, and will try to get it to work as you explained it
Old 16th May 2017, 12:48 PM   #543
grael is offline grael  France
Ah ok, those discussions were about ESS dacs like the TPA Buffalos.
(which can use async reclocking with its own clock, or just sync).
The DDDAC is a pure slave dac.
Feel free to ask when you'll be at it (except about BBB which I don't have...)
Old 16th May 2017, 03:06 PM   #544
So in this way all the pins/lines get exactly where they are supposed to go? That is fantastic!
Old 16th May 2017, 03:20 PM   #545
That's it.
But beware the VDD connector on the DDDAC header.
3.3V or 5V on the wrong pin could possibly damage the Cronus.
You can even cut the pin on the DDDAC board to be safe.
Old 16th May 2017, 06:06 PM   #546
Dang! It works! It's alive! And it sounds very nice.
Thanks a lot, grael!
Old 16th May 2017, 06:43 PM   #547
Good for you!
Enjoy!
Old 10th November 2017, 01:59 PM   #548
drone is offline drone  Germany
who could tell me what do the 4 LED on the Hermes indicate (EN; 1,2,3)?
Thx
Branko
Old 10th November 2017, 03:48 PM   #549
miero is offline miero  Czech Republic
EN on = Hermes is powered on
others are "unused", you can control them if you want:
- P9_11
- P9_12
- P9_13
Also there are 3 pins available for push buttons on J_RE connector, pulled up to 3.3V::
- P9_16
- P9_15
- P9_23
BeagleBone Black with I2S, DSD and SPDIF interface (Linux driver)
http://bbb.ieero.com/
Old 10th November 2017, 04:38 PM   #550
Thank you Miero,
I am asking because on many photos I see all 4 LED on. On my Hermes LED label "2" is not working (double checked orientation and solder joints). I suspect the small IC labeled QA3 has 5,1 V in but only 0,39 V out. Where the other IC (QA1, QA2, QA4) have 5,1 V in an 5,1 V out. As I do not know what type it is I do not know if it is defect or disabled (in software)?
Does someone know replacement type?
Thank you
Branko
Hermes-BBB/Botic cape for BeagleBone BlackHide this!Advertise here!
Support for Botic Linux driver miero Twisted Pear 2479 25th May 2018 06:15 PM
To Raspberry Pi/BeagleBone Black/CuBox/UDOO owners: RuneAudio is looking for testers ACX PC Based 173 10th November 2015 06:44 PM
BBB + I2S + DAC odem81 PC Based 7 6th January 2015 05:10 AM
BeagleBone Black cowboy99 Swap Meet 10 20th September 2014 10:31 AM
My BeagleBone Black + integrated DAC music server / streamer project page Oystein PC Based 7 21st January 2014 09:34 AM
