Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 20th June 2018, 02:29 PM   #721
Russ White is offline Russ White  United States
Russ White's Avatar
Just a note - we have recently updated Cronus to version 1.4 (available now). It now includes and optional inverting of the buffered clock that goes out to the Hermes modules. This give the builder some flexibility on timing - inverting that clock can make edges align better at the FF with certain sources - like the Hermes-RPI - which is currently in testing.
So in 1.4 you will observe one more jumper that simply selects inverted on non-inverted Hermes output clock. Of course at the final output (same clock that feeds the FF) the signal is not inverted - and so all of the signals are aligned to the actual master clock.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 23rd June 2018, 05:11 AM   #722
mcluxun is offline mcluxun  United States
Is there a good place to get 3.3v for logic from cronus?
Old 15th July 2018, 04:28 PM   #723
sbelyo is offline sbelyo  United States
I'm assembling my chronos (v 1.1) and will be using a stereo BIII SE Pro 28 and an Amanero. Am I correct in thinking that I only populate R5, R6 and R7 with the supplied 33 ohm resistors?
And for the divider I short J1:2 for 45.1584MHz / 49.152MHz Rhea Module combo correct? What crystal goes in X1 vs X2?
Old 15th July 2018, 07:38 PM   #724
barrows is offline barrows
Default yes...
I just place all the resistors, mostly to have it look nice! With Amanero, yes, you want use the 1:2 clock divider with the 45.x and 49.x clocks. I would place the pin header though, just for future flexibility.
X-1 is the slower clock family, so in your case the 45.x goes there.
Cronus - It's about time.Hide this!Advertise here!
Long Time DIYer, first time poster... greglenz Introductions 2 4th September 2014 02:01 AM
long time audio, first time hifi tastie Introductions 7 12th December 2012 01:02 AM
Long time listener, first time caller. cihtog Introductions 5 15th April 2012 12:05 AM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
