Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 5th October 2017, 11:05 AM   #611
miero is offline miero  Czech Republic
Output of Cronus matches Buffalo 3 pin mapping (check its documentation).
Input side of Cronus:
- 1 DCK_IN (bitclock)
- 2 GND
- 3 D1_IN
- 4 GND
- 5 D2_IN
- 6 GND
- 7 D3_IN
- 8 GND
- 9 D4_IN
- 10 GND
- 11 D5_IN
- 12 GND
- 13 D6_IN
- 14 GND
- 15 CS (input pin - clock select)
- 16 GND
- 17 MCK (output pin - actual master clock after division (J1 or J2) or direct (J3))
- 18 GND
- 19 3.3V
- 20 3.3V
BeagleBone Black with I2S, DSD and SPDIF interface (Linux driver)
http://bbb.ieero.com/
Old 5th October 2017, 08:04 PM   #612
Abra is offline Abra  Hungary
Miero, thank you for the specification.
Old 15th November 2017, 01:38 AM   #613
sureshm is offline sureshm  Australia
Russ, can I please check if I have understood this correctly. With a Amanero-Hermes-Cronus Combo, the source feeding the Amanero has little influence on the final sound as the i2s going in to the DAC is re-clocked and isolated using a clean power supply? Therefore all the USB products out there that attempt to clean the USB signal/power (Jitterbug, ISO Regen, etc) won't be that effective? A simple rpi3, despite its various flaws, is sufficient to get very good sound as a source feeding the Amanero-Hermes-Cronus?
Old 15th November 2017, 03:03 AM   #614
francolargo is offline francolargo  United States
Originally Posted by MatthewF View Post
I see, thanks for the info!
I think I'll look into developing my own bi-directional isolator board, and will hopefully still be able to use Cronus as masterclock and to re-clock the I2S output from the BBB.
Cheers!
Matthew
Any progress on this, @MatthewF? Do you need the BBB to adapt to various input sampling frequencies, or will one input frequency suffice? If one frequency will do, the USB inputs to BBB work well as a client for streaming material up to 96kHz. SoX on the BBB will truck the USB through to ALSA, from which nicely-clocked I2S exits via the isolators and on to the DAC. I could give you some suggestions on working syntax for SoX and optimal BBB configurations...
Old 15th November 2017, 08:10 AM   #615
Warning: BBB is not fast enough for SoX resampling on a better quality than low!
Old 15th November 2017, 02:28 PM   #616
True - excellent point! To use SoX for USB streams you should decide what sampling rate SoX will use (96k or less) and perform any resampling on the supply side. For good quality filters (such as HQPlayer...) that resampling will require much more CPU than the BBB can muster. However, at 44 and 48kHz, SoX can run IIR or basic FIR filters using the BBB.
In my system, all sources using the USB input are fixed at 48kHz and any resampling happens in those upstream appliances. For these signals, the USB input pathway works great! ...and when the native freq. of the program material is 48k, the sound quality is impressive.
SoX has the lowest latency of the different options I tried for passing audio from video through to the DAC. Here is a command line example:
Without filters the buffer can probably be 1024:
Code:
chrt -f 45 sox --buffer 1024 -r 48000 -c 2 -t alsa hw:1,0 -t alsa hw:0,0
If I add a small FIR filter for mid freq. room modes, then a buffer of 2048 is better:
Code:
chrt -f 45 sox --buffer 2048 -r 48000 -c 2 -t alsa hw:1,0 -t alsa plug:filter1 fir /usr/filter/fir2peak48.txt vol 0dB 0.02
To run an LADSPA filter, the syntax would look something like this - ending with the filter parameters:
Code:
chrt -f 45 sox --buffer 1024 -r 48000 -c 2 -t alsa hw:1,0 -t alsa plug:filter1 ladspa ACDf 21 1 0 240 0.707 0 0 ladspa ACDf 21 1 0 240 0.707 0 0
I experimented with multiple SoX commands to create a speaker crossover but it was very tricky to time-align the different channels. ...not good for sound "imaging".
Frank
Old 15th November 2017, 03:26 PM   #617
Russ White is offline Russ White  United States
Russ White's Avatar
That is correct.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 15th November 2017, 04:15 PM   #618
I should have mentioned that (obviously) you can kill and restart SoX using a different sample rate if your different USB sources can't resample. Its just that SoX won't adapt on the fly without performing linear interpolation. Sometimes that's better than nothing!
Old 22nd November 2017, 09:19 AM   #619
TioFrancotirador is offline TioFrancotirador  Poland
Russ,
So, any plans for RPI Hermes ? + Cronus + Buffalo III Pro + Mercury it would be my ultimate setup
Old 22nd November 2017, 12:20 PM   #620
Russ White's Avatar
Originally Posted by TioFrancotirador View Post
Russ,
Already done - just testing (probably today)
Audio
Cronus - It's about time.Hide this!Advertise here!
Long Time DIYer, first time poster... greglenz Introductions 2 4th September 2014 02:01 AM
long time audio, first time hifi tastie Introductions 7 12th December 2012 01:02 AM
Long time listener, first time caller. cihtog Introductions 5 15th April 2012 12:05 AM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
