Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 26th March 2015, 11:48 AM   #21
Russ White is offline Russ White  United States
Russ White's Avatar
Originally Posted by kinku View Post
Will Cronus Re-clocking Module with 45.1584/49.152MHz Rhea Pair can handle 44.1.khz samples without resampling?
It does no re-sampling. Just clock sourcing and then re-clocking to remove any source induced phase noise.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 26th March 2015, 11:49 AM   #22
Russ White's Avatar
Originally Posted by twluke View Post
Thank you for this info and congratulation on your great works. I'm very happy to have this occasion of ordering these items at last.
BTW, how do you pronounce Hermes? Simply in an English way or somewhat in a French way like a luxurious brand, or even in a way back to the ancient Greek?
I know the question is silly but couldn't resist to ask .
twluke
Thank you.
Classical Greek
Audio
Old 26th March 2015, 11:51 AM   #23
Russ White's Avatar
Originally Posted by GourouLubrik View Post
I guess there will be demand for such a module!
Noted Thanks!
Audio
Old 26th March 2015, 11:57 AM   #24
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Cronus - It's about time.
Incidentally, the clocks on the Rhea modules are Crystek CCHD-957s. The boards allow you to mount just about any clock though.
Old 26th March 2015, 12:07 PM   #25
linuxfan is offline linuxfan  Australia
On the subject of clocks, I was planning to use NDK clocks with the Cronus/Hermes, but some Googling suggests there's a notoriously high variance in performance parameters of NDK clocks, even within the same production batch.
What do others think? Does the choice of Crystek mean assured performance?
Old 26th March 2015, 12:10 PM   #26
... in a way back to the ancient Greek?
Originally Posted by Russ White View Post
Classical Greek
- Cronus is the Greek god who was eventually regarded as the god of time by the Romans.
(not to be confused with "Chronos" the Greek god associated with time-keeping)
- Rhea is the sister/wife of Cronus.
- Hermes is the Greek god associated with speed.
Old 26th March 2015, 12:14 PM   #27
Russ White's Avatar
During antiquity, Chronus(same as Chronos) was occasionally interpreted as Cronus - the ambiguity is intentional.
Audio
Old 26th March 2015, 12:16 PM   #28
Russ White's Avatar
We use Crystek in production precisely because they are consistent - proven - and excellent. But the Rhea boards do fit NDK. And Rhea has local bypass for clocks which require it.
Audio
Old 26th March 2015, 01:01 PM   #29
grael is offline grael  France
Great project!
Seems really nicely done.
May I ask if a Hermes-Pi would be possible?
I know Raspberry Pi doesn't accept Master Clock input, but it can accept Bit Clock input.
So a Hermes-Pi which divides the master clock by the appropriate factor could feed the RPi with a nice bit clock.
Of course, a new alsa driver must be done to select the dividing factor on the board according to the music samplerate, but I don't think it should be too difficult.
Just food for thought!
A lot of Raspberry Pi are around and a Hermes-Pi + Cronus would be the ultimate (synchronous and no delay) solution for them to feed any i2s Dac.
Old 26th March 2015, 01:33 PM   #30
pixelpusher is offline pixelpusher  United States
@syklab
If there is demand we could easily produce a 2:1 multiplexer for connecting two Hermes modules to a single Cronus. Or you could actually use 2 Otto-II right now.
I ordered one Otto-II for this purpose. Do I need two? I had planned to switch I2s to Buff-III from Hermes BBB and Hermes Amanero.
Cronus - It's about time.Hide this!Advertise here!
Long Time DIYer, first time poster... greglenz Introductions 2 4th September 2014 02:01 AM
long time audio, first time hifi tastie Introductions 7 12th December 2012 01:02 AM
Long time listener, first time caller. cihtog Introductions 5 15th April 2012 12:05 AM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
