Smoking Bridges - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 4th November 2014, 10:31 PM   #1
ss007 is offline ss007  United States
Default Smoking Bridges
I have two year old LCDPS that was hooked to a Antek 2x15 100VA transformer and worked great. I wanted to put the PS back in service but Antek is out of stock on the 100VA's so I ordered a 200VA 2x15. Hooked it up, turned it on and immediately blew apart one of the rectifier bridges. And also almost melted the PCB traces going to the bridge. Is 200va just too powerful of a trans for this PS?
Old 4th November 2014, 10:43 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Not at all. If it were 1kW, the voltage is just the same. There must be an issue somewhere else.
Support for Flying Mole Class D, Valve Equipment and designs both new and old. www.jonsnell.co.uk
Old 4th November 2014, 10:51 PM   #3
Thanks, I have another homemade supply using lm317 and 337. Essentialy the same thing as the Twisted Pear supply but using 8 of these SB160E-G Comchip Technology | Mouser rectifiers. I tried the transformer on that and it did the same thing. I'm running out of **** to blow up here!
The connections I believe are right, maybe the transformer is faulty?
Old 4th November 2014, 11:16 PM   #4
Check the the transformer voltage output with a volt meter and compare the voltage with the bridge rating voltage.
Old 4th November 2014, 11:27 PM   #5
I'm trying to make sure I'm not the problem as far as the connections. On a dual secondary transformer is it important to keep the outputs paired as the come off the transfo? So in this picture the blue and green are the secondarys, can either blue go with either green when I hook them to two rctifier bridges?
Old 4th November 2014, 11:29 PM   #6
freax's Avatar
Sure just don't wire them in series. Eg green from one winding to blue on the second winding. That will double the output voltage to 30vAC.
You really need to check the windings with a multimeter and pair them off, label them if you have to with some sticky tape and a marker.
If that wasn't the problem (Wiring it up incorrectly) then there must be a short somewhere in one of the filtering capacitors or somewhere else in the device.
According to this photo the bridge rectifiers are rated for 100v:
http://www.twistedpearaudio.com/imag.../lcbps_kit.jpg
But they are rated for only 2 amps!!
I think you might need to replace the bridge rectifiers and then only use one of the windings. Twisted pair has apparently used a low value BR to keep costs low but it has also prevented the ability to use a 200VA transformer in place of a 100VA one.
I think inrush current killed it.
http://www.vishay.com/docs/88532/3n253.pdf
You have an option you can upgrade the bridge rectifier and that should be the end of it, you can then keep the two windings wired in parallel.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 4th November 2014, 11:32 PM   #7
I get 16v off both sets of 2nd's when I keep them paired as in my last post.
12.5 and 13v if I mix the 2nd's
This leads me to believe it is important to keep them paired, but, would it cause the rectifiers to blow if they are mixed?
Old 4th November 2014, 11:50 PM   #8
Thanks! I wondered about that. So my homemade ps where I used the SB160E-G Comchip Technology | Mouser Rectifiers I had the same problem but it worked fine with a 100va. Those are rated at 1amp but max surge current is 30amp. That won't withstand the inrush?
Old 4th November 2014, 11:57 PM   #9
freax's Avatar
Inrush Current
A 500VA transformer can deliver over 100A if the circuit looks like a dead short to it.
And that is what capacitors look like when they are completely discharged. If its for long enough then it may exceed the bridge rectifiers ratings.
Figure 3A is two captures combined into one, and shows the inrush current waveform captured when power is applied at both the mains zero crossing point and at the peak. The transformer is a single phase, 200VA E-I type, with a primary resistance of 10.5 Ohms. Absolute worst case current is simply the peak value of the mains voltage (nominally 325V (230V mains) or 170V (120V mains)), divided by the circuit resistance. This includes the transformer winding, cables, switch resistance, and the effective resistance of the mains feed. The latter is usually less than 1 Ohm, and allowing an extra Ohm for other wiring, this transformer could conceivably draw a peak of about 26A.
And
Things become more complicated when the secondary feeds a rectifier, followed by a large bank of filter capacitors. Worst case inrush current is still limited by the winding (and other) resistances, but the capacitor bank appears to be a short circuit at the output of the transformer. Depending on the size of the capacitors, the apparent short circuit may last for some time. During this period, the transformer will be grossly overloaded, but this is of little consequence. Transformers can withstand huge overloads for a short period with no damage, and they will normally last (almost) forever even when subjected to such abuse many times a day.
So there are two ways you can go about this, you can install a soft start circuit which sits on the mains side and prevents the transformer from giving massive amounts of amperage to the (temporarily) shorted capacitors and instead charges the capacitors slowly.
Or you can upgrade the bridge rectifier.
Its up to Twisted Pear to tell you wether or not its a good idea to do this.
I would just go back to having a 100VA winding.
Old 5th November 2014, 12:01 AM   #10
Inrush Current
Ok, Thanks so much Freax! I get it now, I'm going to upgrade all the rectifiers.
2 or 4 bridges? Raka Chip Amps 26 29th July 2012 01:53 PM
Bridges for life ! mpmarino Parts 4 11th December 2004 10:11 PM
IXYS Bridges raincheck Pass Labs 2 30th July 2004 01:32 AM
Paralelling bridges? K-amps Solid State 2 6th December 2003 12:54 AM
Why two bridges are better than one? Andypairo Pass Labs 14 15th October 2002 12:25 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
