Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 20th July 2014, 10:50 AM   #61
lintweaker is offline lintweaker  Netherlands
Question MPD tinny audio with 16-bit files
I've been investigating the 'MPD tinny sound with 16-bit files' issue. I think it comes down to period_size being too low.
When MPD plays a 16-bit FLAC file the following hw_params are used:
Code:
access: RW_INTERLEAVED
format: S16_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 90
buffer_size: 22050
When the same file is played with aplay using:
Code:
flac -d <16bit-flac-file> -c | aplay -
I get:
Code:
format: S16_LE
subformat: STD
channels: 2
period_size: 2048
buffer_size: 32768
With mpd (both mainline and my version) the music sounds tinny, with aplay it sounds good.
Any thoughts?
Old 29th July 2014, 11:57 AM   #62
miero is offline miero  Czech Republic
lintweaker: sorry, I've missed your post...
in the mpd.conf there is following line:
# BOTIC fixup: request the lowest period time
period_time "1"
you can try to increase it for increasing period size
but I think the easier solution (for now) is to force 32 bit output using
format "*:32:*"
Old 2nd August 2014, 12:04 PM   #63
Exclamation alsa patches for mainline
Hi Miero,
ALSA tools/libs etc 1.0.28 are out but are still limited to 384kHz. I think it would be a good idea to post your patches for 768000 support. There is now a even a affordable mainstream DAC/headamp combo (iFi micro iDSD) available which supports PCM 768k and DSD512.
If you do not have the time, I won't mind picking this up.
Old 3rd August 2014, 04:14 AM   #64
Lintweaker, the patch for ALSA requires also kernel support. I'll write to alsa-devel next week.
Old 4th August 2014, 11:15 AM   #65
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
Having taken delivery of a BBB I installed from meiro's website the 'as is' Botic distribution yesterday - no problems encountered so thanks for the efforts there.
Over the last few weeks, in anticipation of the Botic cape appearing I've been thinking about how I will control the solution. My preference is a UPnP/DLNA solution and I've been happily using BubbleUPnP as a control point for a while now.
On a couple of Raspberry Pi based renderers I use I've recently switched to Volumio 1.4 as it includes a UPnP/DLNA capability that routes music through to the mpd-based Volumio player. This works very well. I reasoned that conceptually the Botic and Volumio solutions are similar, being customised/optimised Debian distributions so I investigated the Volumio UPnP module;
An UPnP Audio Media Renderer based on MPD
I installed upmpdcli on my BBB by following the install instructions for the Raspberry Pi on the Downloads page and, hey presto, I appear to have a functioning BBB with Botic software and UPnP functionality; I say appear to have because I haven't actually got any audio output kit hooked up to the BBB so I can't hear the ouput but BubbleUPnP sees the device, serves flac files to it and reports playback progress and on the BBB the activity LEDs suggest things are happening.
As UPnP/DLNA is an obvious and established approach to controlling the Botic I thought this might be of interest to others; perhaps someone can give it a listen too?
If there is sufficient interest in this approach it might even be worth including it, or something similar, in the Botic distribution to provide 'out of the box' control functionality as with the Volumio solution?
Cheers
Ray
Old 4th August 2014, 12:20 PM   #66
twluke is offline twluke  Japan
Support for Botic Linux driver
Just off-topic but sorry to say that I've been just wondering why you are calling miero as meiro. Respect for the author might include writing his handle name correctly.
Old 4th August 2014, 12:31 PM   #67
nautibuoy's Avatar
Thanks for pointing out my typographic errors; I have always had a 'blind spot' for some letter combinations and I will try to proof read more carefully in future. There certainly wasn't any disrespect intended and, hopefully, none taken?
Apologies again.
Ray
Old 4th August 2014, 12:50 PM   #68
Ray
Glad to see your kind response. Thank you. Now let's wait for the new botic driver by the author, probably coming up soon, I believe.
twluke
Old 13th August 2014, 11:35 AM   #69
komri is offline komri
I've been following this for some time with interest. I want to interface the BBB to a WM8741 DAC rather than the ESS you're targeting. Are your driver/modifications open source? If so can you please post a link so I can adapt your work as I need?
Simon
Old 13th August 2014, 06:49 PM   #70
komri: Everything that has been published has also source code included in the /sources directory of the SD card image.
However, in the latest published version there is no I2C control enabled, so it might work without changes with your WM8741 if it is set in the autodetect mode. Just connect needed signals.
I do not have Opus DAC, so I cannot test this.
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
