Support for Botic Linux driver - Page 212 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 10th January 2017, 09:29 PM   #2111
twluke is offline twluke  Japan
Originally Posted by ichiban View Post
If I currently have/use ---botic5 on my BBB, can I load botic7-rc via microSD card?
The microSD would have https://rcn-ee.com/rootfs/bb.org/tes...-08-4gb.img.xz
on it?
If you are currently running a botic5 system, you can update it to this botic7-rc3 system by simply installing the .deb file indicated by miero in the #2037 post.
The image file quoted above is only a debian testing (stretch) image and does not contain any botic system. The file can be also used as an intermediary for eMMC boot of a debian system on which you can install a botic kernel provided as a .deb file like in #2037 post.
Old 11th January 2017, 02:37 AM   #2112
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
Thanks, I'll give it a shot.
Old 11th January 2017, 07:53 AM   #2113
cmiu007 is offline cmiu007  Romania
Originally Posted by miero View Post
cmiu007: I'll consider providing compiled MPD against correct ALSA libraries in DEB.
Thank you, looking forward.
Old 11th January 2017, 04:02 PM   #2114
OK, so now I got some errors in the mpd.log, but they are not specific to mpd, rather that the host is down. Is there any way I can find out if this is due to something internal in mpd, or if there is something outside, i.e. a switch or something?
root@botic:/var/log/mpd# tail mpd.log
Jan 23 04:55 : errno: Failed to read: Host is down
Jan 23 04:55 : player: played "music/Led Zeppelin/Led Zeppelin (Deluxe Edition)/Led Zeppelin - Moby Dick (Live in Paris, 1969).aiff"
Jan 23 04:55 : errno: Failed to open "/mnt/music/Led Zeppelin/Led Zeppelin (Deluxe Edition)/Led Zeppelin - Heartbreaker (Live in Paris, 1969).aiff": Host is down .... etc
Old 11th January 2017, 06:28 PM   #2115
ichiban's Avatar
Uh! How would I get the .deb file up onto the BBB so I can run dpkg -i ?
Very much not a Linux pro.
I'm guessing, copy the .deb to a microSD, and use putty to access the BBB.
Don't know how to copy from the microSD to a directory on the BBB.
Any help appreciated
Old 11th January 2017, 10:06 PM   #2116
If you can access and log-in to the BBB by putty, you can use its USB port to mount a USB stick or drive (FAT-formatted) in which the .deb file should be present and can release the dpkg -i command for installation. BTW, IIRC, the USB support by botic5 might have been broken. Anyway, you might want to try it.
For putty connection, this page will be of help. Tera term is my favorite in Windows environment.
OTOH, though I'm not a user of Logitech Media Server, it seems that you have a private network and your BBB is connected to the server via ethernet. Correct? If so, you can directly log-in to the BBB from termina software, either Win or Mac, and can get the .deb file by wget command and install it. Apologies if I'm wrong.
Old 12th January 2017, 02:48 AM   #2117
ichiban's Avatar
Got a windows tty program to copy the .deb file over to the BBB.
Ran dpkg -i on the BBB, see results below, then rebooted the BBB.
My worst fears came true, only one led blinking on the BBB, normal
is two leds alternately blinking.
IP scanner now doesn't show it.
...the package install results below...
root@botichost:~#
root@botichost:/# date
Wed Jan 11 22:08:32 EST 2017
root@botichost:/# ls -la etc/dpkg
total 13260
drwxr-xr-x 4 root root 4096 Jan 11 22:10 .
drwxr-xr-x 73 root root 4096 Jan 11 18:43 ..
-rw-r--r-- 1 root root 446 Jun 12 2013 dpkg.cfg
drwxr-xr-x 2 root root 4096 Feb 15 2015 dpkg.cfg.d
-rw-r--r-- 1 root root 13557072 Jan 11 22:11 linux-image-4.8.13-botic7-rc3_1_armhf.deb
drwxr-xr-x 2 root root 4096 Feb 15 2015 origins
root@botichost:/# dpkg -i /etc/dpkg/linux-image-4.8.13-botic7-rc3_1_armhf.deb
Selecting previously unselected package linux-image-4.8.13-botic7-rc3.
(Reading database ... 23263 files and directories currently installed.)
Unpacking linux-image-4.8.13-botic7-rc3 (from .../linux-image-4.8.13-botic7-rc3_1_armhf.deb) ...
Setting up linux-image-4.8.13-botic7-rc3 (1) ...
update-initramfs: Generating /boot/initrd.img-4.8.13-botic7-rc3
zz-uenv_txt: Updating /boot/uEnv.txt [uname_r=4.8.13-botic7-rc3]
root@botichost:/#
Old 12th January 2017, 04:19 AM   #2118
root@botichost:~#
total 13260
root@botichost:/#
Well, nothing wrong with the installer message above. Did you check the line of "dtb=am335x-boneblack-botic.dtb" is included in /boot/uEnv.txt?
Old 12th January 2017, 04:29 AM   #2119
ichiban's Avatar
Did not check that, what is it?
Don't know what to do now that it doesn't
boot up.
Perhaps if I boot from a microSSD card with
a good Botic I probably can get in!?
Oh! I see that in post 2110, damn! did not remember to do it!!
Old 12th January 2017, 05:21 AM   #2120
boot up.
Can you boot the BBB from eMMC? If so, you can edit your botic SD card by mounting it.
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Copyright 1999-2017 diyAudio
