Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 31st May 2014, 11:19 PM   #11
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Originally Posted by Salar View Post
According to this thread @ twistepearaudio, a Placid HD BP draws about 890mA. Adding some headroom, letīs say 1.5A.
In this scenario,the math says 22.5VA should be sufficient, correct?
All the best,
Sal
That's not at all what that thread is saying.
The Placid is not drawing that much; the boards he is powering is drawing that much. The Placid, by itself, will draw slightly more current than you set it to shunt.
You need to determine the load you are presenting to the Placid (what modules you are powering), plus the shunt overhead.
The size of your transformer is dictated by this, not the Placid itself.
Old 1st June 2014, 09:16 AM   #12
Salar is offline Salar  Germany
Hello Brin!
Thank you for the reply. I will power the Buffalo III DAC and IVY. So how much current (including reasonable shunt overhead) will they draw?
All the best, Salar
Old 1st June 2014, 10:15 AM   #13
smooth dancer is offline smooth dancer  Norway
My BIIIse with Tridents draws around 550mA (with Exa) Shunting appr.60mA
Ivy around 150mA ( 75mA from each half on Placid BP ). Shunting appr. 60mA
In my BIIIse's the I2C header feeds Exa usb-I2s device with 3v. If not using the I2C on BIIIse, I guess 490-500mA current is correct.
Old 1st June 2014, 01:20 PM   #14
Hello Smooth Dancer,
60mA shunting is for the new HD Placids?
Then absolute minimum transformer should probably be:
BIIIse = 610mA x 9V = 5.5 VA
IVY = 210mA x 15V = 3.1 VA
I guess even 10VA for the Buffalo IIIse and even 5VA for the Ivy should be
sufficient without stressing / heating the transformer?
Anyway, for my design I will choose the "old" transformer ratings of 15VA for the Buffalo and 30VA for the IVY.
This is almost three times available current for the BIIIse and almost ten times current for the IVY.
All the best,
Salar
Old 21st July 2014, 06:00 PM   #15
AlexanderTD is offline AlexanderTD  Ukraine
I finally installed my new custom made 100VA trafo (placid 2.1, 13V) and the difference is...huge.
To be honest - i didn't expect this, but a friend of mine who professionaly work in this field told me that because my stock 30W trafo was getting warm\hot - it is a bad sign and it may be working out of it's optimal\linear range and only then i finally i decided to try replacing it...
To make description short - the improvements are largely in dynamics and bass with some additional cleanness as bonus. The buffalo was always nice and clean, but slightly anemic compared to my other dac. Now the dynamics is overhelming and it got what was missing - the "bite" and attack as well as firm bass.
So i guess one should not use Legato 3.1 with anything less than 50W
Old 21st July 2014, 06:55 PM   #16
He he,,,I use 250va on each of my Ivy's. Becouse it works like a dream. Better bass and dynamics.
Old 23rd July 2014, 06:53 PM   #17
Duffy Moon is offline Duffy Moon  United Kingdom
Duffy Moon's Avatar
How would this happen? I could understand maybe clipping with not enough power, but better sound with excess power? Can someone explain the science?
How many VA are sufficient for the Placid Power Supplies?Hide this!Advertise here!
FS Buff II DAC + Placid PSU + IVY III + Placid BP PSU - $350 ianp Swap Meet 1 23rd March 2013 03:38 AM
FS: Buffalo II DAC + Placid Combo, Legato I/V Stage, 2x Placid BP Modules damohpi Swap Meet 4 23rd November 2010 09:51 AM
+/-15V power to a TI PGA2310. 15V regulators sufficient or do I need adjustable?? nick_g_evans Parts 2 16th July 2008 12:50 PM
Transformer VA versus output power VA nigelwright7557 Solid State 8 18th May 2008 03:57 PM
Sufficient power for the Fountek JP-2.0? mazeroth Multi-Way 3 20th April 2005 04:37 AM
Copyright ©1999-2017 diyAudio
