Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 19th March 2014, 03:40 PM   #1
boriss111 is offline boriss111  United Arab Emirates
Default Opus output filter
Hi all,
I have Opus DAC for with output filter based on simple schematic shown in attachment. The circuit was drawn in LTSpice, so it features LT1028, but in reality the Opamp is currently NE5534 - will be replaced with LME49710 or OPA134.
I was expecting that this setup will sound equal or better than old TDA1541, but it doesn't. It sounds a bit shallow and bright.
As improvement, I am considering some of the following:
1. Remove the 22uF capacitors on DAC output - this should be safe thing to do; even if + and - outputs from Wolfson do not have 100% same DC level, it shouldn't damage the filter; correct?
2. Increase the supply voltage from +/- 11V to +/- 15V and put Class A PS instead of Low Current Bipolar Supply; does this make any sense?
3. Remove the 4.7uF MKT from the output of the filter - again, even if there is an error on the Wolfson output, given the unity gain of the filter, there shouldn't be danger for the amplifier, right?
Thanks for help.
Boris
Old 20th March 2014, 12:58 PM   #2
Russ White is online now Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
The resistor values are on the high side - noise will suffer.
Have you tried the IVY-III? It sounds excellent with the Opus.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 20th March 2014, 07:14 PM   #3
Hi Russ,
Would you recommend to use those 22uF & 100k on Opus output with IVY?
Boris
Old 21st March 2014, 02:34 PM   #4
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Originally Posted by boriss111 View Post
Hi Russ,
Boris
No, they are not needed when using the IVY.
Old 21st March 2014, 03:02 PM   #5
How about capacitor after IVY? Do you recommend one or it is not needed?
Boris
Old 22nd March 2014, 05:16 AM   #6
Boris
Not needed.
Old 26th March 2014, 11:06 PM   #7
Wolfsin is offline Wolfsin  United States
Default really?
hmmm, really? A little looking around here and on the TP support site suggest that the sound of the Opus & Ivy combo might fall short of excellent. The following almost kept me from building the IVY III even though I had the kit in the closet.
Originally Posted by pinnocchio View Post
I currently own a Opus DAC from TPA and use it with the IVY III line stage but I don't really like the IVY III...
There are resistor changes in the Ivy manual for Opus because the BOM is for Buffalo but, oddly, no change for the four 15nf caps. I have 3.3nf replacements on order but have not yet tried them. It is my theory that the low-pass filter that results from 15nf affects the upper audible range negatively.
'gardz, Dick
Old 26th March 2014, 11:24 PM   #8
Russ White's Avatar
I wouldn't let that set you off - there are many more who have tried it and loved it.
It works very well - and is my personal favorite output stage for the WM8741.
Audio
Old 29th March 2014, 09:37 PM   #9
My theerory likely is not the issue since the filter resistors between ESS and Wolfson are unchanged. I am using the WM8740 and did not populate or power the ballsie except that the IC had been soldered in place. To compensate I have temporarily replaced my HD600s with a pair of rewired MDR-V6s that IMHO are normally short of bass response until the 3.3nf caps arrive.
I believe this is a popular pcb, built and enjoyed by many. I feel confident that with smaller filter caps it will work well for me too. When I remove it from between the Opus and opc's BAL-BAL the HD600s sound great.
'gardz, Dick
Opus output filterHide this!Advertise here!
WM8741 opus dac to BA/SE LTR110Transformer Output Stage hironimo Digital Line Level 0 28th November 2013 09:12 AM
Need output transformer from Telefunken OPUS PP mx5500 tubenut99 Parts 0 5th November 2013 11:34 PM
Looking for output stage for Opus DAC 32y0 Digital Line Level 0 17th May 2010 11:03 AM
Output filter Skorpio Class D 5 8th August 2008 07:44 PM
Output filter m-tech Class D 11 22nd September 2007 08:04 AM
Copyright ©1999-2017 diyAudio
