Building an open embedded audio applicance.
How's this am I close? :)
Any more detail available yet?
I'm working on drilling my chassis for my new 'ground up' Buffalo 3SE DAC build and particularly interested in what sort of power regulation the Botic board has, which will inform my decision on the sort of power supply I need to include for it (i.e. costs/benefits of simple linear vs shunt power supply; because of the Trident shunt regs on the 3SE I plan to use a simple linear regulated supply for it, using less space and producing less heat with minimal compromise on performance).
Ray
