Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 7th April 2014, 04:48 PM   #511
clsidxxl is offline clsidxxl  France
clsidxxl's Avatar
Russ,Have you considered the NDK NZ2520SD http://www.ndk.com/en/products/searc...7929_1433.html ,excellent specification,but very very small.The CCHD-957 is very good ,I use it with the FIFO of Ian.
Old 7th April 2014, 08:03 PM   #512
ChrisMmm is offline ChrisMmm  New Zealand
ChrisMmm's Avatar
Originally Posted by clsidxxl View Post
Russ,Have you considered the NDK NZ2520SD NZ2520SD(OA / AV)/Crystal Clock Oscillators/NDK ,excellent specification,but very very small.The CCHD-957 is very good ,I use it with the FIFO of Ian.
And, dare I say it, the NDKs are a lot cheaper. Depending on how you source them of course. From what I have read performance is similar.
But this isn't a democracy, Russ makes the choice and I would abide by that.
Old 7th April 2014, 10:23 PM   #513
PET240 is offline PET240  Australia
Regards the LCD and Russ looking at using the bbb to write to the registers on a dac(Buff III-refer earlier in the thread), could an lcd be connected via the spi bus? Or if a dac is connected that way can only one device be connected at a time?
Also, another software I used(mpdpup) would load two songs into ram(thats what I understood anyhoo), so when the first finished the second was ready to crank, the question I have is, could the sample rate and format be "read" by software and at end of song the dac registers could be changed if required to automagically be setup for whats coming next. I dont know delays or dramas, just spitballing.
An lcd isnt really necessary for this black duck, just my brain throwing ideas into the ether.
Russ, with the two clocks are we going to have a mclk u.fl term so we can run the buff synchronous if we desire? Be nice to have u.fl connectors for the i2s as I am looking at running through a fifo, though if you are reclocking on the cape this may not be at all necessary.
Thankyou again gents for your efforts, looking forward to hearing them!
Chuz,
Drew.
Old 8th April 2014, 03:37 AM   #514
acko is offline acko  Australia
Originally Posted by Nikon1975 View Post
I am a bit lost in this development. I'll have my BBB in two months, so I have to stick with the Rasberry Pi for the time being. I am enjoying it, using both the I2S and I2C to control the DAC. If there is interest I can share the results (that are kind of trivial) here or in a dedicated thread. What I am trying to do is to modify volumio to make it use I2C to control the volume. Now I manage to do it only with command line. Help is also appreciated.
Does the driver developed for BBB do the same ?
What's the final goal of the whole development ?
Thanks,
D.
Yes, agree, goals and clarifications needed!
This is a great project that Russ have initiated but we before we get carried away lots of development we need to look at it from other perspectives and the reasons for going about this way. My knowledge in Audio streaming is limited at the moment but reading between the lines the Embedded Audio Appliance is practically a duplication of established lifestyle products and I can see better systems out there in this regard.
But if Russ can come up with synchronous BBB cape then I am also in for it.
But then again if you already have Ian's FIFO this would make the 'cape' redundant and I reckon the FIFO is a better product for post processing. So for those who have an RPi and Ian's FIFO you practically have everything you need now for full sync operation onto ESS DACs. Plus VolumeIO, the convenience and performance is right in your hands now.
But the 'BBB Cape' can have other advantages (apart from being a compact add-on) that Russ could explain to us.
Sorry, I didn't mean to cast aspersions but I am just commenting from a technical point of view. Hope I can be proven wrong
AckoDAC Project
Old 8th April 2014, 03:47 AM   #515
Acko,
The only real downside is Ians FIFO doesnt do dsd, I have one of all his boards so am not dissing his efforts in any way. Since I am looking to record my vinyl in dsd I would like to be able to play it back natively in dsd as well.
Appreciate yoir thoughts and insights.
Chuz,
Drew.
Old 8th April 2014, 03:51 AM   #516
BrianL is offline BrianL  United States
Building an open embedded audio applicance.
clsidxxl, ChrissMmm,
The NDK doesn't have close-in phase noise specs, and w/o that, it's hard to say whether they are worth messing with.
bel
Old 8th April 2014, 04:03 AM   #517
Originally Posted by PET-240 View Post
Acko,
Chuz,
Drew.
Thanks, all for this cape then.
Great work!
Of course since the cape isolates and improve the clocking scheme we would expect this to provide super audiophile quality or am I expecting too much for a product like this?
Old 8th April 2014, 04:51 AM   #518
I have a feeling Russ knows what people would be liking/wanting/requiring/dreaming/hoping for, so I would say he intends to the benchmark.......
Chuz,
Drew.
Old 8th April 2014, 10:06 AM   #519
4est is offline 4est  United States
If one likes their other products, we should have some faith that Russ and Brian will do it well. Russ made it clear that he wants this to be high quality in its first iteration.
Old 8th April 2014, 01:45 PM   #520
miero is offline miero  Czech Republic
Raw BBB is able to generate only multiples of 48kHz frequency using very poor clock. So it is usable neither for CD nor DSD.
Raw RPi can generate both frequencies, but it drops some ticks to keep frequency accurate on average. And it does not support DSD, neither it has ability to use better clocks so no bit perfect.
Building an open embedded audio applicance.Hide this!Advertise here!
Tractrix in 1*Pi and 2*Pi revintage Multi-Way 21 26th August 2011 09:37 PM
PI Speakers Haknhendrix Multi-Way 1 13th November 2003 06:52 PM
What is 2 pi and 4 pi EternaLightWith Multi-Way 12 13th October 2003 01:28 AM
PI-Filter wuffwaff Solid State 39 3rd January 2002 01:05 PM
