Buffalo III I2s problem - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 13th December 2013, 08:55 PM   #11
Russ White's Avatar
Send a message via Yahoo to Russ White
I was just going to ask the same thing.
No good reason to use I2S over SPDIF here.
Less pulp more juice Twisted Pear Audio.
Old 13th December 2013, 10:06 PM   #12
glt is offline glt  United States
Hi Russ,
Merry Christmas!
cringvig, try moving the i2s wires as far away from anything else as possible. Or move the cable around and see if it affects the locking.
www.hifiduino.wordpress.com
Old 14th December 2013, 02:33 PM   #13
Hi All
Thanks for your replies.
I have tried to move things and wires around with no luck.
Last night i had the DAC connected to the M2tech evo with the i2s output and was just a cutted ethernet cable and it worked perfectly.
So in this case the wires did not make a problem.
The AE does only have internal i2s or toslink out so it is not possible to test with s/pdif.
What about the FIFO reclocker ?
Chris
Old 14th December 2013, 02:56 PM   #14
Russ White's Avatar
Toslink is SPDIF So if you can find the signal to the transmitter you can use that. Use a voltage divider to get it close to consumer level. Something like 221R series and 75R to GND.
Old 14th December 2013, 05:09 PM   #15
OK got it
Maybe I am wrong but I have always been thinking that i2s is to prefer when availible instead of SPDIF as it is the native DAC input ?
Chris
Old 14th December 2013, 05:43 PM   #16
Russ White's Avatar
Depends on who you believe.
In any case it also depends on what actually works - and how the source is designed.
You can do I2S as badly or worse than SPDIF, and in any case the ES9018 does not handle SPDIF like most SPDF receivers do at all. It handles it far better and asynchronously.
Old 17th December 2013, 10:31 AM   #17
Hi Russ
I have found the spdif out from the AE and with the divider you suggested the voltage is about 0.6V
I connected to the Buffalo DAC but it would not lock.
Tried the same wires on another DAC and it did lock right away with no drop outs.
Then I had the scope on at the same time and saw that the voltage is pull down to 0.3V.
Hmm... tried the i2s again and it will not lock and the voltage is pulled down from 3.2V to 0.5V when connected to the Buffalo DAC.
When I removed the wires from the DAC the signal is 3.3V and 2.8Mhz.
What has happent here ?
Both SPDIF and i2s is pulled down when connected to the Buffalo DAC
Chris
Old 17th December 2013, 12:01 PM   #18
Russ White's Avatar
Are you remembering to change the IP_S jumper/switch?
Old 17th December 2013, 02:08 PM   #19
Hi Russ
Thank you for quick reply.
Yes I did remember the jumper and it make no difference.
I think something must have happend to the Buffalo board but I have no clue as I do not have the schematics.
On the picture the yellow channel is directly from the signal generator and the blue one is from the signal generator to the Buffalo DAC.
I have been re-soldering all the junctions I have made myself.
I really need some advise what to check.
Chris
Old 17th December 2013, 02:21 PM   #20
Russ White's Avatar
At what exact points are you measuring?
Does the same thing occur for all inputs?
If anything failed it would be one of the input multiplexors.
Buffalo III - SE Russ White Twisted Pear 558 9th March 2017 08:36 PM
Multichannel I/V stage for Buffalo III? Crumboo Digital Line Level 16 15th November 2015 11:47 PM
WTB: Buffalo III kit neofeed Swap Meet 2 1st March 2013 09:32 AM
looking for a Buffalo III Dac Spodin Swap Meet 0 26th October 2012 09:07 AM
Buffalo II audio dropouts SPDIF/I2S noise ground problem merlin el mago Digital Line Level 9 2nd May 2010 11:21 AM
Copyright 1999-2017 diyAudio
