Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 17th December 2013, 04:00 PM   #21
cringvig is offline cringvig  Denmark
It is the same between GND / SPDIF and GND / DCK.
I can measure 75 Ohm between GND / SPDIF and 14-17 Ohm between GND and DCK.
The DAC is on the LAB at my job but as i remember GND / D1-D2 was several Mohm.
Does it give you a idea if it could be one of the multiplexors ?
I got setup for SMD but I really hope there is nothing wrong with the DAC itself
Chris
Old 17th December 2013, 04:21 PM   #22
Russ White is offline Russ White  United States
Russ White's Avatar
Yes unfortunately it sounds like the multiplexor associated with DCK is dead - or that signal is otherwise shorted. Probably ESD, but this is the first I have ever seen anything like that. They are pretty robust.
There is nothing between the mutiplexor and the DAC input pins other than a high value resistor to GND to keep the signal referenced to GND.
I suppose it is also remotely possible that the DAC input pin itself is shorted or has been damaged - but this seems less likely. I would check the other possibility first. Simply removing the multiplexor and then checking resistance from that resistor to GN will tell you if the short was before the DAC pin or not.
The measurement at the SPDIF input is perfectly fine.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 17th December 2013, 05:15 PM   #23
Ok this is strange as I work with ESD sensitive PCB's on daily basis and are very carefull about this.
Anyway, could you please give me the component number for the multiplexor related to the DCK so I can find it.
Also the type so I can find a replacement at farnell or RS ?
What worries me is that the DAC before was able to lock at the spdif and now it won't.
Russ, thank you for your help I really appreciate it.
Chris
Old 17th December 2013, 05:23 PM   #24
Russ White's Avatar
It may not have been ESD - I really have no way of knowing. All we know for sure is that input was not in this condition earlier since you were locking from the signal generator.
I will PM you some more info.
I am happy to help, very sorry for the misfortune.
Audio
Old 11th January 2014, 09:52 AM   #25
Just a update, it was not just one but all three at the i2s inputs there where defect.
At the moment they are removed and I use the spdif input.
The respective inputs are grounded and a wire has replaced the last multiplexer.
The setup with the AE is cancelled as I think it can be the reason for the blown up inputs.
The new setup is as follows :
Raspberry PI connected to LAN by wire and and the buffalo DAC connected to the PI throught M2tech hiface 2.
Volumio is the software I use and now I am able to stream with airplay from the Imac and use the ipad as remote.
In pitperfect quality.
Quite a decent sound for such a user friendly setup.
Thanks to Russ for supporting throught this critical time in life where your DAC is down
Best regards
Chris
Old 15th January 2014, 10:31 PM   #26
Russ White's Avatar
Thanks for the report Chris! I am very happy to help, especially folks like you.
Glad your set now. Your project sounds very interesting I would love to see more! Feel free to start a thread.
Audio
Buffalo III I2s problemHide this!Advertise here!
Buffalo III - SE Russ White Twisted Pear 566 28th November 2017 11:03 PM
Multichannel I/V stage for Buffalo III? Crumboo Digital Line Level 16 16th November 2015 12:47 AM
WTB: Buffalo III kit neofeed Swap Meet 2 1st March 2013 10:32 AM
looking for a Buffalo III Dac Spodin Swap Meet 0 26th October 2012 10:07 AM
Buffalo II audio dropouts SPDIF/I2S noise ground problem merlin el mago Digital Line Level 9 2nd May 2010 12:21 PM
