Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 3rd September 2013, 11:24 PM   #11
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
You can't install them wrong. They work the same either way as they are 1:1 transformers. Still I think Brian will be posting pictures soon.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 3rd September 2013, 11:36 PM   #12
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
On the test rig...
The forth transformer position is jumpered because I was testing different input types (AES/EBU, consumer S/PDIF, TOSLINK module in consumer mode, TOSLINK in TTL mode). TTL worked fine with or without the transformer, though I would probably opt to not use it.
EDIT: Also, note the direct mounting. I now include a female header to mate to the male header on the Buffalo, securing it with standoffs.
Old 6th September 2013, 01:07 AM   #13
Spoon109 is offline Spoon109  United States
Male / Female standoffs work much better. Lucky for me, I have some left over from another project.
4 channel S/PDIF level converter availabilityHide this!Advertise here!
I2S to S/PDIF converter krassyg Digital Line Level 2 13th October 2011 01:31 PM
Multichannel I2S to S/PDIF converter lacipeti Parts 0 5th October 2011 12:15 PM
USB-S/PDIF converter and DAC paulb Digital Line Level 22 14th June 2010 05:57 PM
Optical 2 S/pdif converter? Ryssen Digital Line Level 21 29th January 2009 11:05 PM
S/PDIF to analog converter Limhes Digital Source 4 29th April 2005 01:55 AM
Copyright ©1999-2017 diyAudio
