Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 17th April 2013, 12:03 AM   #21
Russ White is offline Russ White  United States
Russ White's Avatar
BTW if you did the same thing with a PCM and DSD source the result is the same, but you would need an OTTO_II (or equivalent) to test that.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 17th April 2013, 12:04 AM   #22
Russ White's Avatar
Also I just want you to know I appreciate your intent. I don't mean to sound too critical.
Audio
Old 17th April 2013, 12:14 AM   #23
vortecjr is offline vortecjr  United States
vortecjr's Avatar
Originally Posted by Russ White View Post
The DAC is behaving as it should... You are proposing hobbling the DAC for PCM for the sake of DSD. If you want to do that you can use Buffalo III. It's inputs are wide open.
I have not had any issue with any player that I have tried with my firmware so far, and I have no reason to suspect I would unless that player in faulty, in which case why would I want to use it?
I seriously doubt anyone else is doing it exactly the way I am. I wrote my own implementation.
Which player is giving you trouble?
I'm not sure what hobbling means. I have the Buffalo III, but I swapped it for the Buffalo IIISE. You say the player is faulty, but it works fine into another Saber32 DAC Email me and I'll respond with the players and interfaces I used.
Old 17th April 2013, 12:27 AM   #24
Russ White's Avatar
Of course it will likely work fine into a DAC wired only for DSD because it never tries to play the faulty PCM... Not sure what that proves.
if you want to wire something for only DSD, then use the B3.
Audio
Old 17th April 2013, 12:34 AM   #25
vortecjr's Avatar
All these DACs are wired to play DSD or PCM and the intent is to play both without regard to the order in the playlist.
Old 17th April 2013, 12:38 AM   #26
Russ White's Avatar
Oh? Can you please state exactly which signals are routed to which inputs on these DACs for stereo input that support both PCM and DSD with no switching? Ours follows Dustin's directions.
Audio
Old 17th April 2013, 12:44 AM   #27
vortecjr's Avatar
Here you go:
Bit Clock / DSD Bit Clock
Word Clock (LRCK) / DSD Data Left
Data / DSD Data Right
GND / GND
Old 17th April 2013, 12:46 AM   #28
Russ White's Avatar
Originally Posted by vortecjr View Post
Here you go:
GND / GND
Saying this as nicely as I can, that does not tell me anything. You need to describe it at the IC level.
Audio
Old 17th April 2013, 01:27 AM   #29
vortecjr's Avatar
I mis-understood the question. On test #1,#2 and #3 I used my Buffalo IIISE as is. The inputs are tied together and auto re-mapping function is on. I don't have the details on test #4 except what I wrote in the first post. He is using what you call the "faulty player" and he is not getting any POPs.
Old 17th April 2013, 01:28 AM   #30
Russ White's Avatar
Without the details there is no use in having this conversation at all.
Audio
Buffalo IIISE DSD playback issue - nasty POP soundHide this!Advertise here!
DSD Playback system, DSF Player + USB DDC + DSD Amplifier KOON3876 Digital Source 120 14th November 2017 07:25 AM
FS: Twisted Pear Buffalo IIISE kit MrMajestic Swap Meet 6 10th April 2013 07:20 PM
November 8th, 2012 - DSD Pioneer, Andreas Koch of Playback Designs fork Clubs & Events 0 25th October 2012 05:50 AM
Nasty pop when I power down Captn Dave Tubes / Valves 1 6th December 2009 11:20 PM
