adding output tubes stage to the buffalo 2 - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 6th May 2013, 10:33 PM   #21
4est is offline 4est  United States
Thank you Mars2! I am about to try my BII with UTC HA 100x @1:10. I am hoping that I have enough gain, but am thinking I may not with the 1ohm resistors I am going to try. Some sort of balanced (or SE I suppose) 12ax7 tube circuit is first choice.
Originally Posted by mars2 View Post
@4est:
I mean in general using a low resistor (not low Z transformer) as I/V directly at the output of the chip, followed by a min. 10x step-up transformer (f.ex. a MC-transformer).
The following tube stage should then be a high-gm/transconductance one (5842, D3a, 6E5P etc.).
CFP output stage adding more output transistors diy didi Solid State 2 2nd February 2013 07:15 PM
Buffalo III Simple Output Stage Help? davecandialex Digital Line Level 3 23rd December 2012 05:04 PM
FS:Buffalo DAC II with tube output stage Nikola Krivorov Swap Meet 2 12th February 2011 07:08 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
Copyright 1999-2017 diyAudio
