Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 22nd June 2013, 08:02 PM   #81
miero is offline miero  Czech Republic
Will it be for beta testing soon? I'd like to try it...
Old 23rd June 2013, 01:31 PM   #82
johnwmclean is offline johnwmclean  Australia
Originally Posted by pixelpusher View Post
Do you have the dimensions of this USB module?
Originally Posted by Russ White View Post
Soon!
I am re-factoring the design to make it a bit more modular.
Any idea on the dimensions at this stage?
Bigger or smaller than the current module?
Old 24th June 2013, 10:31 AM   #83
C37 is offline C37  Belgium
The patent would only apply to the technique I use in the firmware
I am not sure what you would need to get your patent going. If it's funding maybe you could start a Kickstarter project, i am pretty sure that knowing the number of users of buffalo dacs worldwide you could collect enough to get you going and you could reward people who have pledged money by avoiding them the waiting lists later on for example or offering them a return on sales price.
Just an idea, but since waiting for the TP's USB module i have spent quite a bit on other modules and would like to use yours. It would be very frustating for everyone to know that when the module arrives it's actually a restrained version. Just my 2c...
Ohm sweet ohm
Old 24th June 2013, 02:53 PM   #84
ferrilu1 is offline ferrilu1  Italy
...I agree with C37.
gf
Old 26th June 2013, 07:14 PM   #85
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
And what is that special feature about? I am not asking how it works, but any clue of what can it provide to us
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 26th June 2013, 07:30 PM   #86
jcx is offline jcx  United States
an individual US Provisional Patent Application is only $100 - gives you a priority date, a year to file a full patent application - contents are not visible until a fixed time after a full application
Old 27th June 2013, 09:22 PM   #87
thomaspf is offline thomaspf  United States
There have been some changes to the provisional filing earlier this year. I would check with a patent lawyer what that really gives you if you release the product before you do the actual patent application.
Cheers
Thomas
Old 27th June 2013, 10:25 PM   #88
Russ White is offline Russ White  United States
Russ White's Avatar
I don't think I can describe it without giving it away.
Brian and I are just working out some last minute part changes.
Fortunately I am now on vacation from my day job, and will have a few days to work on this stuff. Woot!
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 29th July 2013, 02:05 AM   #89
Spirit02 is offline Spirit02  Peru
Things still kicking along Russ?
Old 29th July 2013, 02:24 AM   #90
Russ White's Avatar
Yes, I knocked together a new prototype last week, and it works fine.
Brian and I have been discussing the effects of various options on the digital output side of things.
We will be posting some findings soon and asking for some feedback based on what we know. it is too early to mention all of those yet however.
In short I have discovered there are some non-trivial considerations around isolation and re-clocking.
The short of it is - that any of the new "fast" isolaters will inject jitter (phase noise) the same way the XMOS chip itself does. This is because they work using an internal modulator (in Mhz - like the XMOS master clock) so any signal will have up to 2 x the modulator period jitter transposed onto each isolated signal. Not so bad for word clock and data, but not great for bit clocks and master clocks at high sample rates.
Don't have time to go in too deep tonight, but I will share more soon.
The bottom line is, things are still moving, but as I learn more and more the module has morphed a lot.
Cheers!
Russ
Audio
The Asynchronous USB Audio class 2 module.Hide this!Advertise here!
Asynchronous USB DAC clock source Hitec Digital Line Level 8 19th April 2016 02:02 PM
LPC3130 for asynchronous USB to I2S jonsmirl Digital Line Level 16 11th November 2012 01:12 AM
USB asynchronous output to to DUEL AES jsa_ind PC Based 1 26th April 2012 03:49 PM
Cheap Asynchronous USB jkeny Digital Line Level 5 26th September 2009 11:24 AM
Cad Audio - another Class-D module raintalk Class D 0 9th November 2004 10:09 PM
