The Asynchronous USB Audio class 2 module. - Page 5 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 11th March 2013, 08:14 AM   #41
Originally Posted by Russ White View Post
If I focus only on output - omit SPDIF - I could probably do up to 8 channels output only.
The problem is - I definitely want both input and output.
So perhaps after this module is done - I will turn my energy to an 8 channel output only version.
and please do not forget to make them 32-bit 384KHz capable, as for i2s
If for pristine and pure adoration - it's diyAudio dedication!
Old 12th March 2013, 10:43 AM   #42
gwikse is offline gwikse  Norway
Looks great. I am looking forward to testing it when it is awailable.
However, one tweak done to the exa card is to cut the 5Vusb and apply 5V from the dac`s supply. This has a big effect on the sound and I hope this will be possible on your module as well. In other words external power to both the usb-side and the audio-side. If there is need for regulation I would also like to have the option of using tridents instead of normal off the shelf chip regs.
JRMC (PC) / ROON (RPI-ROONbridge) | .... DIY ..... | Nordost Heimdall | AP Virgo V
Old 14th March 2013, 12:14 AM   #43
henry97 is offline henry97  United States
Instead of wires or cables to connect USB card to Buffalo IIISE, are there an option of some kind of connector likes Molex, Amp .....ect ?
Old 14th March 2013, 05:30 AM   #44
Pretty sure u.fl count as connectors.
Old 15th March 2013, 04:59 AM   #45
I mean .....A male connector on one card and a female on the other, just plug them together without wire or cable.
Old 16th March 2013, 12:34 PM   #46
Murdoc is offline Murdoc  Germany
Originally Posted by Spirit02 View Post
Hi Russ,
I would love to have this capability, with the endgame objective to be able to utilise the volume control of the Buffalo (2) directly from within windows, without having to use an arduino or similar.
Really glad it's finally all coming together
Phil
Hi Russ,
I'd love this too, but a bit modified:
"I would love to have this capability, with the endgame objective to be able to utilise the volume control of the Buffalo 2+3 directly from within Linux (and other OS), without having to use an arduino or similar."
Old 25th March 2013, 01:04 AM   #47
Do you have the dimensions of this USB module?
Old 25th March 2013, 11:45 PM   #48
Russ White's Avatar
Send a message via Yahoo to Russ White
Soon!
I am re-factoring the design to make it a bit more modular.
Less pulp more juice Twisted Pear Audio.
Old 26th March 2013, 12:08 AM   #49
Overkill Audio's Avatar
Default Great product
Hi Russ,
Just wanted to add my support and interest in this product.
For me the holy grail features of DSP filters and Buffalo volume control would make this a dream product.
Thanks in advance and hope your 2013 makes up for 2012...
" Within every adversity lies the seed of an equal or greater benefit"
All the best
Derek.
Old 26th March 2013, 12:18 AM   #50
Russ White's Avatar
Thanks Derek!
I really appreciate the support. A little encouragement can go a long way.
One of the reasons I am going more modular is to keep the opportunity to for such advanced features open. Though the first iteration will be a bit simpler.
Cheers!
Russ
Asynchronous USB DAC clock source Hitec Digital Line Level 8 19th April 2016 02:02 PM
LPC3130 for asynchronous USB to I2S jonsmirl Digital Line Level 16 11th November 2012 01:12 AM
USB asynchronous output to to DUEL AES jsa_ind PC Based 1 26th April 2012 03:49 PM
Cheap Asynchronous USB jkeny Digital Line Level 5 26th September 2009 11:24 AM
Cad Audio - another Class-D module raintalk Class D 0 9th November 2004 10:09 PM
Copyright 1999-2017 diyAudio
