Legato 3, Common Mode DC and You. How do you choose to deal with it? - Page 6 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 28th November 2012, 03:30 PM   #51
4est: I am recalling correctly that you run JC-1s? If so, can you confirm no issues running the L3 without caps into them?
The JC-1, I am pretty sure, has a servo in the input stage, so it might be OK with a little bit of offset anyway, but I am going by memory here and am not certain.
Old 28th November 2012, 06:50 PM   #52
4est is offline 4est  United States
Yes Barrows, I am running JC-1s. I am not sure about the inputs, but it did work.
Old 28th November 2012, 06:59 PM   #53
BrianDonegan's Avatar
I struggle with the idea of lifting the ground and floating 8-9v on the input pins, seems as if begging for trouble.
It's only 8-9V when there is a ground. Without ground, it's 0V. It's all relative.
Old 28th November 2012, 09:40 PM   #54
RollE2k is offline RollE2k  Sweden
So leaving GND floating on the output of legato i/v, there wouldn't be any trouble feeding these directly into the grids my balanced tube-linestage?
Old 28th November 2012, 11:07 PM   #55
Yes, but ground is everywhere, well er umm, should be!
Old 29th November 2012, 12:03 AM   #56
Default The beauty...
of floating grounds. I prefer floating grounds, no AC ground reference, no connection of signal ground to AC ground. This way, with balanced connections, all grounds are "virtual". This also eliminates circulating ground currents.
Warning: this is not recommended for people building their own stuff! Not connecting the AC ground might kill you! But I do it anyway, and so do some very well established major audiophile component makers of which I am aware.
With the nCores I am pretty sure this method will work well: BIIIse/Legato3 with no AC ground connection, no signal ground connection to XLR-cable-nCore amp, with pin 1 connected to chassis, no AC ground connection. No loops, no signal ground connection so no offset.
I know floating grounds seems to freak some people out, but it has worked quite well for me for awhile now, silent...
Old 29th November 2012, 01:10 PM   #57
Default DO NOT DO THIS, EVER
AC Ground (Earth) SHOULD ALWAYS BE CONNECTED TO YOUR EQUIPMENT CHASSIS. ALWAYS. NO EXCEPTIONS.
Old 29th November 2012, 09:26 PM   #58
Russ White's Avatar
Send a message via Yahoo to Russ White
That is true to a point, but 0V does not *have* to be DC coupled to say the mains earth. For certain the chassis and Mains GND should always be joined for safety.
From a signal point of view 0V is relative, and when talking about signal GND(0V) that does not necessarily need to be connected to mains GND at all. Though many times it is.
Less pulp more juice Twisted Pear Audio.
Old 30th November 2012, 05:58 PM   #59
Yes sir! That is what I meant, but still, the digital grounding gave me cause to wonder. I am running i2s, and unlike SPDIF, there is no transformer to assist in isolation. To be honest, I didn't think it all through, but I didn't want to force my DAC to signal ground >i2s>usb and>cpu. I guess I just assumed that the digital ground was tied to the Legato ground.
Old 30th November 2012, 06:28 PM   #60
Russ White's Avatar
That's the nice thing about balanced signals. GND is common mode. So there is little to fear about joining a digital ground.
Also, a great option if you want to not join digital and analog GNDs is to use a pair of teleporters. I have see people do this even between components in the same chassis, seems a bit overkill to me, but hey, you can do it.
Legato 3.1 balanced out to my Aleph J (Common mode DC) habsrock93 Pass Labs 8 13th October 2011 10:40 PM
common mode choke help milen007 Power Supplies 11 14th March 2011 04:40 AM
common-mode chokes jarthel Tubes / Valves 6 11th February 2008 03:31 PM
common mode questions zahlm Parts 1 24th May 2004 08:38 PM
Common mode chokes Dr.H Digital Source 1 24th July 2002 04:47 PM
Copyright 1999-2017 diyAudio
