AVCC 2.1 - module update - Page 9 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 14th December 2012, 01:38 PM   #81
I use the Legato 3. I think it is pretty darn good. I did use PRP resistors in audio path. The TP combo blew away my Rega Saturn, (which is long gone).
Old 14th December 2012, 02:08 PM   #82
Russ White's Avatar
Send a message via Yahoo to Russ White
Originally Posted by Erlend Sæterdal View Post
Anyway I have built something better I think.
I would be stunned if didn't say so.
BTW - the legato can be used very easily with only bipolar transistors. Just one one in each set instead of three. It works quite nicely. In fact the first Legato worked that way.
Less pulp more juice Twisted Pear Audio.
Old 14th December 2012, 02:25 PM   #83
Old 5th January 2013, 05:15 PM   #84
Salomon is offline Salomon  Germany
Salomon's Avatar
Sorry, in my application the new AVCC 2.1 does not sound as good as the old version.
I lose much musicality and much resolution of the higher frequencies.
The Buffalo III have lost all its attributes who I love on it.
The I/V stage that I use is the balanced single ended FET version from this thread:
A New Take on the Classic Pass Labs D1 with an ESS Dac
Changing the plugged AVCC to the old version solved the problem an all was fine.
I know my DAC and his good sound for a long time and now I know how important the AVCC board for the sound performance is.
Should I burn in the new AVCC for a few days?
I can´t believe it.
I am hearing with my Aleph-X and Martin Logan Logan Request Electrostatic speakers.
With the Trident V3 there is no problem. They are good and will stay in my Buffalo.
Has someone an idea what i should make now?
Old 5th January 2013, 05:26 PM   #85
Russ White's Avatar
Not sure what your hearing, but I can assure you I would never go back to the old version. As you can see by the replies I doubt almost anybody else would either.
Leave it for a while, maybe it will grow on you.
Old 5th January 2013, 05:31 PM   #86
analog_sa's Avatar
Maybe you have managed to fine tune your system and any deviation now makes it sound worse. I recently upgraded my old AVCC with OPA2211 and the change is entirely positive. Took them about a day to settle down.
Old 5th January 2013, 07:38 PM   #87
Salomon's Avatar
Thank you for your answers!
Ok, so I´m going to hear a few days with the new version.
Because the other users are happy with the new version, I am looking now for a mistake in my DAC.
Which voltage on each output of the Buffalo board should I adjust with the trimmers of the IV-Stage? Pleease see my attachment.
I have heard half of the AVCC supply voltage is the best choice.
Now I use the Buffalo board with a static voltage of 1,7V on each of the four Output-Pins
Is 1,7V ok?
Old 6th January 2013, 04:33 PM   #88
Russ White's Avatar
1.7V is fine. 0V is also fine. Performance in this regard really depends more on the I/V stage than the DAC itself.
Old 6th January 2013, 06:38 PM   #89
I can´t believe it.
I think it is the rest off your system. The new AVCC is without faults. Your system perform better with the fault.
Old 22nd January 2013, 10:06 AM   #90
dahlberg's Avatar
Is there any possibility to buy "old avcc's", I would be interested
in two ?
class D amplifier module,power amplifier module sunlight009 Vendor's Bazaar 2 19th October 2011 02:02 AM
AVCC regulator module merlin el mago Twisted Pear 2 5th March 2011 03:43 PM
WTB BII AVCC module merlin el mago Swap Meet 4 8th February 2011 03:13 AM
Endangered Audio - Gristleizer Module & New Module Line! endangeredaudio Vendor's Bazaar 0 5th March 2010 04:03 PM
Graphic VFD module - Preamp Update mhennessy Digital Source 7 19th November 2002 06:58 PM
Copyright ©1999-2017 diyAudio
