#21 |
Less pulp more juice Twisted Pear Audio. |
#22 |
Hi Russ,
I'm sure the question has already been asked, but why does the AVCC need to share the voltage reference..? in other words, why can't Tridents be used in place of the AVCC module ? |
#23 | |
It happened to me and I found it was when the Shunt Power supply to the Buffalo board was under powered (too low CCS setting..).. you should check that you are shunting enough current in your Placid if that's what you use... |
#24 |
You can absolutely use two trident's but the left and right output will then not be as exactly matched, and any variation will not be present on both sides at the same time. This can have an adverse effect on stereo imaging.
#25 | |
www.hifiduino.wordpress.com |
#26 | |
OR are you talking about the 2 leds on the same module? IE 2 leds in the same photo? |
#27 |
Actually there could be ~1ma difference in current through the LEDs.
The reason is the base current of the transistors that reference the LED. Still if the voltage is in the right range they should be very similar.
#28 |
ETA on the new AVCC modules?
Thanks JD |
#29 |
A few weeks. They are being built now...
Twisted Pear Audio |
#30 |
Is it soup yet?
JD |
| Thread Tools | Search this Thread |
| class D amplifier module,power amplifier module | sunlight009 | Vendor's Bazaar | 2 | 19th October 2011 01:02 AM |
| AVCC regulator module | merlin el mago | Twisted Pear | 2 | 5th March 2011 02:43 PM |
| WTB BII AVCC module | merlin el mago | Swap Meet | 4 | 8th February 2011 02:13 AM |
| Endangered Audio - Gristleizer Module & New Module Line! | endangeredaudio | Vendor's Bazaar | 0 | 5th March 2010 03:03 PM |
| Graphic VFD module - Preamp Update | mhennessy | Digital Source | 7 | 19th November 2002 05:58 PM |
