Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 8th November 2012, 02:56 PM   #71
BrianDonegan's Avatar
Originally Posted by Hercules View Post
Hi Russ/Brian, I'm using BII with trident, can I reuse the trident from BII to BIII SE??? upgrading from BII with legato 3 will be just remove and install new BIII SE, all header will be same as before?
Yes, you can. Like the B-III, the B-IIIse is slightly longer than the B-II, but the mounting points are in the same locations.
Twisted Pear Audio
Old 8th November 2012, 04:03 PM   #72
Default Multiple inputs on IIISE
Will there be a way to have multiple inputs; at least two SPDIF, and a USB when that comes available
Old 8th November 2012, 04:03 PM   #73
Russ White's Avatar
Send a message via Yahoo to Russ White
Originally Posted by juw View Post
Hello,
this might be a dumm question (in that case please excuse):
I understand that the Buffalo III SE was build to ease the usage for stereo und mono setups. As the Buffulo III isn't available any more (at the moment), I wonder whether or not the SE version also can be used / setup for multi-channel usage?
Thanks!
Uwe
You could use multiple DACs, handling 1 or 2 channels each.
Less pulp more juice Twisted Pear Audio.
Old 8th November 2012, 04:18 PM   #74
Thanks for the answer
How about the AVCC??? As two package of BIII SE, $299 one got the DAC board only, so the AVCC module from BII can be reuse also??
Old 8th November 2012, 04:29 PM   #75
This is covered here:
Consumer-level S/PDIF for BIII
Twisted Pear Audio
Old 8th November 2012, 04:38 PM   #76
You can do that, but you will have two different AVCC versions.
Twisted Pear Audio
Old 8th November 2012, 04:54 PM   #77
yes, I just notice the latest AVCC is V2.1, mine is V1.0, tridents also V1.0
Old 9th November 2012, 12:32 AM   #78
Now accepting pre-orders. Will begin shipping 16-Nov.
The Buffalo-IIISE (Stereo Edition) 2-Channel DAC
Twisted Pear Audio
Old 9th November 2012, 12:48 AM   #79
lhquam is offline lhquam  United States
Does anyone have suggestions for sizing an enclosure for the Buffalo-IIISE, IVY-III, 4-input SPDIF, Metronome, USB DAC receiver, and power supplies? I would like some "elbow room" for possible other things.
Old 9th November 2012, 12:54 AM   #80
I would like a sanity check on this configuration that I would like to order:
Buffalo-IIISE
IVY-III output stage with Placid HD BP power supply
Placid HD power supply
TOSLINK input board
4-channel SPDIF input board
USB DAC receiver
Metronome
Transformers: 9V and 15V
Will all of this play together?
Buffalo III - flexibility without compromise. Russ White Twisted Pear 1270 16th May 2013 07:23 PM
Buffalo III Build Thread dheming Twisted Pear 8 7th May 2012 01:13 PM
Buffalo III and Integer / HOG jtwrace Twisted Pear 5 19th January 2012 05:41 PM
WTB: Buffalo II/III DAC merlin2069er Swap Meet 1 10th January 2012 05:50 PM
Copyright ©1999-2013 diyAudio
