Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 24th November 2017, 09:49 PM   #561
drone is offline drone  Germany
after reading through the BIIIse-Pro thread I got some questions about the new tridents-sr.
1: Would the tridents-sr/avcc-sr be also of benefit for the BIIIse (ES9018) with latest trident/avcc (shunt version). Or is this only true for ES9028/9038?
2: Should the voltage also be set up to 3.3/3.3/1.3 trident and 3.6 avcc?
Branko
Old 25th November 2017, 12:40 AM   #562
Russ White is offline Russ White  United States
Russ White's Avatar
Branko
1 - Absolutely! In fact I tested first with the ES9018.
2 - Yes - that scheme works well with that DAC as well.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 27th November 2017, 05:32 PM   #563
yammy1688 is offline yammy1688  United States
Send a message via AIM to yammy1688 Send a message via MSN to yammy1688
I've got a BUFFALO III (non SE) that I finally had the time to put together. Left channel has distortion, especially noticable in a certain high-ish range. Otherwise fine. Any ideas what it could be?
Old 27th November 2017, 05:54 PM   #564
Russ White's Avatar
It's hard to say - what output stage?
The first thought is that it is possibly a dead/damaged AVCC module? If you have a very old AVCC module I would highly recommend updating to the AVCC_SR.
Cheers!
Russ
Audio
Old 28th November 2017, 06:11 PM   #565
I'm using the original IVY. It is OK because if I put a BII back on there, it's distortion-free.
I tried replacing the AVCC from another BIII and it doesn't seem to help. Tried another source (both original OPUS). Anything else I can try swapping out?
Old 28th November 2017, 08:52 PM   #566
Russ White's Avatar
Hmmm - it's starting to sound like the ES9018 itself... Are you using stock firmware etc?
Audio
Old 28th November 2017, 10:03 PM   #567
That's kind of a bummer. I haven't done any flashing of any kind so It should be. Are you referring to the ESS chip itself or the bios chip that can be popped out?.
Old 2nd June 2018, 05:15 AM   #568
jf4828 is offline jf4828
FYI, if anyone is interested in taking over my BIII SE/Cronus/Hermes/BBB streaming project.....
Buffalo III SE Streaming DAC For Sale
Buffalo III - SEHide this!Advertise here!
Buffalo III - flexibility without compromise. Russ White Twisted Pear 1377 12th July 2018 04:37 PM
Buffalo III Build Thread dheming Twisted Pear 11 26th February 2014 02:30 AM
Buffalo III and Integer / HOG jtwrace Twisted Pear 5 19th January 2012 05:41 PM
WTB: Buffalo II/III DAC merlin2069er Swap Meet 1 10th January 2012 05:50 PM
