Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 8th January 2017, 08:54 PM   #551
Russ White is offline Russ White  United States
Russ White's Avatar
Originally Posted by reactivepower View Post
My Emotiva amps were not happy with the common mode DC. They have static and/or snapping noise when used with the legato. I went back to the IVY III as a result.
You might have tried AC coupling. But I am also very partial to the IVY-III
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 8th January 2017, 11:53 PM   #552
audioslave is offline audioslave  United States
Thanks Russ,
I was going to upgrade the caps on the previous Legato I was using....but by the time you buy some really good caps I could just buy the Legato III. I called the folks at Ayre and they corroborated that it doesn't really matter as they have a fully balanced design. You just cant always tell based on the literature from the manufacturers.
BTW I did really notice a improvement switching to the DC coupled version. The amp is also DC coupled as well. Sounds pretty good for no caps and no global feedback...
Looks like the first stab at the PRO I/V will be op-amp based. Are you guys going to have a few options in the future ala IVY and Legato? I know you cant make any promises...just asking.
Thanks again for all the work you guys do. Its great to feel like you have some skin in the game by assembling the parts/system. Having the option to upgrade over time part by part is fun as well.
Mike
Old 20th February 2017, 05:35 PM   #553
francolargo is offline francolargo  United States
Quick question to which I don't recall ever reading the answer:
Would it be possible to achieve good B3se performance in synch mode with the I2S transported via Teleporters? Asynch performance is very good, of course. Could one expect the same performance as synch mode without Teleporters? I also wonder if the master clock from Cronus version 1 would be robust enough to supply 3 teleporters. It would be a hassle at this stage to learn by experimenting...
TIA,
Frank
Old 28th February 2017, 10:37 AM   #554
drone is offline drone  Germany
Default B3SE micro controller
HI,
bring for the first time to use an arduino (due) to control the B3se.
Did not figure hit hoW to connect to the IP_S header.
If I short the Pins with jumper I2S input is playing fine. Also if taking jumper away Spdif is playing fine.
Setting my SELECT2SPIN low and connecting it to the left pin ( underneath the IP mark) Spdif is playing. But If set the SELECTI2SPIN high (3.3 V) and connect it to the same pin nothing happens and Spdif input is still playing instead of I2S input.
How would I have to connect a micro controller to the IP_S select header?
Thx
Branko
Old 5th March 2017, 02:10 AM   #555
sbelyo is offline sbelyo  United States
Connecting sources for a dual mono configuration:
For spdif from what I read it is ok to parallel the connection to both boards. Is this correct?
I can't find a clear example of how the I2S is connected. I understand that the length must be short and it's best to use ufl cable. What is the best method?
Old 6th March 2017, 08:01 PM   #556
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Buffalo III - SE
Originally Posted by drone View Post
HI,
Thx
Branko
Are the DAC and controller sharing a ground?
Old 6th March 2017, 08:15 PM   #557
Buffalo III - SE
For both S/PDIF and I2S, just run them in parallel. Do not daisy chain the connections, however. Make individual runs from the source to each DAC.
Old 7th March 2017, 05:12 PM   #558
got it...
Thanks Brian
Old 9th March 2017, 08:36 PM   #559
Buffalo III - SE
More boards should be arriving any day, so I just opened up pre-orders, shipping end of next week. That *should* give me enough time to build
Old 14th October 2017, 04:55 PM   #560
Russ White's Avatar
A lot of you folks will be interested in this:
Introducing the Buffalo III-SE-Pro 9028/9038
Cheers!
Russ
Audio
Buffalo III - SEHide this!Advertise here!
Buffalo III - flexibility without compromise. Russ White Twisted Pear 1373 17th January 2018 10:39 AM
Buffalo III Build Thread dheming Twisted Pear 11 26th February 2014 02:30 AM
Buffalo III and Integer / HOG jtwrace Twisted Pear 5 19th January 2012 05:41 PM
WTB: Buffalo II/III DAC merlin2069er Swap Meet 1 10th January 2012 05:50 PM
