Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 18th October 2013, 02:37 PM   #331
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Buffalo III - SE
Originally Posted by RollE2k View Post
what is the output voltage to the "lock" led? and which is the current-set resistor for the led? - thinking about using a blue led there which does have ~3.2v forward voltage.
Blue LEDs usually require a lot more current, and could damage the ES9018, unless you add a buffer (R+Q). Off the top of my head, it is 3.3V. The resistor is easy to find, just follow the trace back toward the chip (at work, so I cannot look).
Old 18th October 2013, 02:40 PM   #332
RollE2k is offline RollE2k  Sweden
Approx what current does run through the leds right now?
I won't need more than maybe 4mA max, so that wouldn't be impossible i think? :-)
Old 19th October 2013, 05:29 PM   #333
Could you check this Brian? 3-4mA ok? :-)
Old 19th October 2013, 09:26 PM   #334
picovolt is offline picovolt
Unhappy S/PDIF & Ground shorted out
I have not had my board hooked up yet. While waiting for other parts, decided to solder on the uFL sockets onto the board—I did the s/pdif first, since until I have a USB interface, I'll be using toslink. After I soldered it, I tested continuity, and the ground and s/pdif were shorted. So I unsoldered the connector, thinking that I must have gotten a solder bridge under it. No—all was clean. It is still shorting though, which I can't imagine is correct. The pads are clean, there is no visible solder to connect them. Is it possible that solder got into the mid layers? Any way to fix this? If not, will this affect the PCM/DSD input? I used very little solder—.015 diam. with a rtiny tip (.020?) on my Hakko. Heat was at 640 F.
Old 20th October 2013, 12:38 AM   #335
Buffalo III - SE
R2 and R5 feed the LEDs. They are both 357R, yielding roughly 9mA to the LEDs.
Old 20th October 2013, 12:39 AM   #336
Buffalo III - SE
Can you post a picture of the pads?
Old 20th October 2013, 02:54 AM   #337
Default pads close up
Here's a macro shot with low angled lighting. I'm including a quick shot of the housing I've made while waiting the 5 months for the final parts (MJE for BP supply, Mouser is shipping this week!!)
Old 25th October 2013, 10:25 AM   #338
DQ828 is offline DQ828  Australia
DQ828's Avatar
I like the case very much, not sure about the soldering though
I shouldn't talk I fried a track to the lock light & had to do a micro repair, you might be able to do a similar thing, if you can work out where the grounding is occurring.
Old 25th October 2013, 02:23 PM   #339
I'm hoping to. The soldering didn't look bad, until I had to solderwick off the connector and then, when it was still shorted, kept using more solderwick in the area to soak up as much as I could. But obviously I did screw something up with the soldering. For work I've been building small boards with many 0603 LEDs on them, and felt pretty confident about putting the uFL connectors on. I've looked at the immediate area with a 20x scope (boy is it nasty looking at that scale!) and from the board exterior don't see any bridging. There are those tiny holes around the ground pads, and my worry is that somehow solder went through those and might be shorting traces in the mid layer. If that's the case, then the only fix I can imagine would be grinding away the uFL area pad connectors there to get inside—but certainly want to wait until I get Brian's answer about whether the short could be happening in a mid layer (1) and if I grind away just that area (say the rectangle defined by the outer edges of the two uFL ground pads) are there other traces in the mid layers that I'd be totally mucking with (2).
Thanks about the case—the front is wood from your neck of the woods—Australian Lacewood.
Old 25th October 2013, 03:04 PM   #340
4est is offline 4est  United States
Nice case, I like the lace wood!
Buffalo III - SEHide this!Advertise here!
Buffalo III - flexibility without compromise. Russ White Twisted Pear 1373 17th January 2018 10:39 AM
Buffalo III Build Thread dheming Twisted Pear 11 26th February 2014 02:30 AM
Buffalo III and Integer / HOG jtwrace Twisted Pear 5 19th January 2012 05:41 PM
WTB: Buffalo II/III DAC merlin2069er Swap Meet 1 10th January 2012 05:50 PM
