Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 19th August 2013, 03:24 PM   #321
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Buffalo III - SE
Originally Posted by JM Popaleetus View Post
Hey all, I have a quick question in regards to the SE's output when used in voltage mode (I/V distinction may even be irrelevant to the answer).
Is the output active-balanced or impedance-balanced? Meaning is there a signal on the + and - pins, or is the - pin just impedance matched to the + pin?
Thanks!
The outputs are true balanced outputs.
Old 19th August 2013, 07:18 PM   #322
JM Popaleetus is offline JM Popaleetus  United States
JM Popaleetus's Avatar
Thank you Brian.
Old 19th September 2013, 11:05 AM   #323
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
What is the voltage output swing of the buffalo III SE?
I checked the manual and it says about output current, but didn't find anything about voltage.
I'm that guy who finds ways *not* to do things..
Old 20th September 2013, 10:16 AM   #324
Nikitas's Avatar
No one knows?
Old 20th September 2013, 10:43 AM   #325
wktk_smile is offline wktk_smile  Japan
wktk_smile's Avatar
I'm not familiar with IIISE version, but with Buffalo II
If I remember correctly,
each phase has maximum voltage swing of AVCC*0.9/2 or so, depends on the load.
high value load = more voltage swing, less current swing
low value load = less voltage swing, more current swing
virtual GND, near zero ohm = nearly no voltageswing, full current output
Old 20th September 2013, 10:47 AM   #326
Nikitas's Avatar
Thanks for the reply!
Just a thought, with these levels, why would one need a legato, ivy d1 or anything else, and not connect the output of the dac to an i/v resistor and then straight to a power amp, say a NCORE?
Given (of course) that everything would be in the same box.
Old 20th September 2013, 11:01 AM   #327
wktk_smile's Avatar
It should be necessary to squeeze better THD performance.
described in the whitepaper, page4
http://www.esstech.com/PDF/sabrewp.pdf
I personally have positive experience with voltage mode - outputs followed by transformers
Good locational presentation, while it does not harm the fidelity so much.
Old 20th September 2013, 11:16 AM   #328
Nikitas's Avatar
hmmmm, cross-read it, saw the part about the "extremely good op-amp".
So, if one connects dac->R i/v->amp like LME49990+LME49610 should be ok. So no need for a line stage.
Again, given that everything is in the same box.
Old 20th September 2013, 12:24 PM   #329
Buffalo III - SE
The ES9018's outputs are not strictly current-output, like many other DACs. Using an I/V R directly on the outputs will induce modulation of the DAC's output stages resulting in increased distortion.
If you want to bypass an output stage (and filtering), it would be better to drive the N-cores directly, though the performance will not be a good as if you used a proper active I/V stage (near 0 input impedance).
Old 18th October 2013, 01:39 PM   #330
RollE2k is offline RollE2k  Sweden
what is the output voltage to the "lock" led? and which is the current-set resistor for the led? - thinking about using a blue led there which does have ~3.2v forward voltage.
Buffalo III - SEHide this!Advertise here!
Buffalo III - flexibility without compromise. Russ White Twisted Pear 1373 17th January 2018 10:39 AM
Buffalo III Build Thread dheming Twisted Pear 11 26th February 2014 02:30 AM
Buffalo III and Integer / HOG jtwrace Twisted Pear 5 19th January 2012 05:41 PM
WTB: Buffalo II/III DAC merlin2069er Swap Meet 1 10th January 2012 05:50 PM
