Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 29th January 2013, 02:49 AM   #271
Greg Stewart is online now Greg Stewart  United States
Buffalo III - SE
Originally Posted by ionian View Post
Hello Rus White,
<SNIP>
I am using ESI Juli@ sound card's digital parts only on the transport PC. I'm planing to I2S output from Juli@ and input to Buffalo. How can I do this? Is that true plan?
http://usr.audioasylum.com/images/4/...falowiring.bmp
What do I need to purchase from you to get started, but complete?
My Requirements for DAC:
- 1 S/PDIF (RCA) input
- 1 I2S input
- 2 RCA outputs
- 12V battery input
- I dont want to use stage at started. May be later
Thank you.
Ionian,
I've connected a number of DAC cards directly to the Juli@ digitial section, including a Buffalo 32. Please contact me via PM and I can send you pictures detailing the connection.
One caution is that it works best when the connection is kept very short... millimeters matter here. I've always mounted the DAC card directly on top of the Juli@ digital section. If you need to locate the BuffIII SE farther away, consider using a pair of TP's Teleporter modules. I'm currently working this setup up for a new DAC using a Buffalo-II.
Also, when using an I2S input, I don't think you'll need any S/PDIF connection.
Greg in Mississippi
Everything matters!
Old 30th January 2013, 07:15 PM   #272
ijscobar is offline ijscobar  Netherlands
Banned
Originally Posted by dahlberg View Post
I went for u.fl at the "WaveIO" and soldering at the buffalo end.
Tried soldering the u.fl's but it was a little bit tricky so I skipped that.
Trying to connect my WavIO board. I only need to connect these three wire's to get it to work?
Old 30th January 2013, 07:17 PM   #273
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Buffalo III - SE
Yes, plus GND if you are not using coax.
Old 30th January 2013, 07:21 PM   #274
Banned
I'm using coax!
Thanks!
Old 5th February 2013, 08:39 AM   #275
Banned
I connected the WaveIO board like the drawing above but it won't lock.
When using SPDIF with a M2Tech HiFace 2 everything works fine.
Do I need to set switches on de BIIISE board in a different setting?
(If so I must have misread Leons manual completely...)
Old 5th February 2013, 08:51 AM   #276
neskor is offline neskor  Serbia
Did you try:
The active input signal can be
selected by connecting a switch to the switch pad (IP_S, 3) or by an external controller:
Input Switch Controller Pins
S/PDIF Open High SPDIF, GND
PCM/DSD Closed Low DCK, D1, D2, GND
Old 5th February 2013, 09:03 AM   #277
Banned
Originally Posted by neskor View Post
Did you try:
No did not try that. I'll see if I have a switch somewhere and try.
Thanks!
Old 5th February 2013, 09:07 AM   #278
You don't need switch, just short two pins on IP_S connector with PC jumpers:
Old 5th February 2013, 09:19 AM   #279
Banned
I don't have a connector in that place, don't have one at home either. Have a switch connected as we speak and it's locking. Now see if I can get any sound from it...
Old 5th February 2013, 09:39 AM   #280
Banned
It's alive! Thanks Neskor!
Buffalo III - SEHide this!Advertise here!
Buffalo III - flexibility without compromise. Russ White Twisted Pear 1373 17th January 2018 10:39 AM
Buffalo III Build Thread dheming Twisted Pear 11 26th February 2014 02:30 AM
Buffalo III and Integer / HOG jtwrace Twisted Pear 5 19th January 2012 05:41 PM
WTB: Buffalo II/III DAC merlin2069er Swap Meet 1 10th January 2012 05:50 PM
