Buffalo III - SE - Page 27 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 18th January 2013, 08:08 PM   #261
ionian is offline ionian  Turkey
Hello Rus White,
First of all, sorry for my English is poor.
I'm a bit new to the diy DAC world. I'm using a computer basic transport with BNC output. My amp is a SET with 300B tube (6V output).
I am using ESI Juli@ sound card's digital parts only on the transport PC. I'm planing to I2S output from Juli@ and input to Buffalo. How can I do this? Is that true plan?
http://usr.audioasylum.com/images/4/...falowiring.bmp
What do I need to purchase from you to get started, but complete?
My Requirements for DAC:
- 1 S/PDIF (RCA) input
- 1 I2S input
- 2 RCA outputs
- 12V battery input
- I dont want to use stage at started. May be later
Thank you.
Old 19th January 2013, 08:35 AM   #262
LeonvB is offline LeonvB  Netherlands
- 1 I2S input
- 2 RCA outputs
- 12V battery input
Please read the guide, esp. the part "Bill of materials for stereo mode DAC". The document should answer most of your questions. I would strongly suggest adding an I/V stage.
Old 26th January 2013, 05:27 AM   #263
nvduybom's Avatar
Originally Posted by Russ White View Post
DVCC should be 3.3V - it must be damaged.
My DVCC is 3.4V , it is ok ? .
Old 26th January 2013, 06:30 AM   #264
Likely, yes. 3.4V is only a 3% deviation from what you expected. Most DMMs are not calibrated plus their accuracy is usually not as great as the amount of digits on the display suggests.
Old 26th January 2013, 02:58 PM   #265
Russ White's Avatar
Send a message via Yahoo to Russ White
Yes it is within the safe margin.
Less pulp more juice Twisted Pear Audio.
Old 26th January 2013, 11:40 PM   #266
While I certainly think providing a synchronous clock can sound really good - it can also sound worse (especially if you end up with longish clock routes).
Russ, is there a maximum length of clock route (using coax) you could suggest..... or write in stone?
Old 26th January 2013, 11:43 PM   #267
Russ White's Avatar
With uFL you should be able to do 6" without any issues.
I use some 6" uFL with excellent results. I have not tried to go any further. It may work fine - I just don't know There is more than one factor in play.
Old 28th January 2013, 03:21 AM   #268
Thanks Russ.
Old 28th January 2013, 01:19 PM   #269
Banned
My BSEIII has just come alive... Now thas's a nice step up from Opus!
Old 28th January 2013, 07:30 PM   #270
Russ White's Avatar
Good work! Glad you are enjoying it.
Buffalo III - flexibility without compromise. Russ White Twisted Pear 1362 27th December 2016 04:11 AM
Buffalo III Build Thread dheming Twisted Pear 11 26th February 2014 02:30 AM
Buffalo III and Integer / HOG jtwrace Twisted Pear 5 19th January 2012 05:41 PM
WTB: Buffalo II/III DAC merlin2069er Swap Meet 1 10th January 2012 05:50 PM
Copyright 1999-2017 diyAudio
